Canon DR-7080C Flatbed Scanner Logo
A
Anonymous Posted on Jan 05, 2012
Dr 7080c scanner have jam 148 - Canon DR-7080C Flatbed Scanner
4 Related Answers
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Jun 30, 2008
SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Anonymous
  • Posted on Mar 12, 2009
SOURCE: fix scanner dr 7080c
We had the same problem and called a Canon technican to come out.
Open the lid, take the two screws on the left-hand side out, so you can remove the flatbed glass.
You will have to remove one or two metal plates to get the glass out. Be very careful with the glass!
Now you can get to the mirror part. You should be able to put it back into place.
Hopefully this helps!
Anonymous
  • 31 Answers
  • Posted on Jun 10, 2009
SOURCE: Canon DR-7080C Missing page size selection in scan properties
tried this? http://software.canon-europe.com/software/0025523.asp?model=
Paul Kois
  • 332 Answers
  • Posted on Apr 01, 2011
SOURCE: Hi. I am looking
I have many years of repairing Canon scanners and here is my suggestion to you.
You can also get them on the US site also, I will include the link for the drivers in this response. The problem your going to have is that to upgrade your firmware you need a piece of software to upgrade the firmware on your scanner. That piece of software is only released to canon dealers and its also used for diagnostic's of your scanner and to make adjustments to your scanner. I would contact your local Canon dealer, and ask what they would charge you if they came out to do this service for you, or what would they charge you if you brought the scanner to them to cut down on the cost of this very simple update. It only takes a couple of minutes to upgrade your firmware on your scanner. Below is the link to Canon's website for the files you need. I hope this helps you out.
http://www.usa.canon.com/cusa/support/office/imageformula_scanners/imageformula_dr_7080c/imageformula_dr_7080c_color_production_scanner#DriversAndSoftware
Testimonial: "This is the first time I have used your website. Thanks for the speedy and extremely professional response!"
1helpful
1helpful
Hi. I am looking for Vista drivers for the Canon DR-7080C. I see some on the Canon Europe website but it says I need to upgrade the firmware and I am not sure which version the scanner has already. Any...
I have a Canon DR-7080c. I am getting a thin horizontal black line in the same spot on all of my scans. Sometimes it's lighter than others but I have tried cleaning glass and adjusting the dpi and...
If the 'noise' is in the same place with varying intensity it is definitely dirt on the glass. Clean with Isopropyl alcohol (rubbing Alcohol). Dont use any solvent.
S. Mohan
1helpful
Scanner not found when pick scanner setting
Have you installed the device drivers? You can download drivers from Canon Europe. Run scandisk on your computer just to eliminate any OS issues.
S. Mohan
Canon DR7080C Scanner - top feeder not responding
Clean the rubber rollers with Isopropyl alcohol. Pls dont use solvents. Daily you need to wipe the scanner and rollers with a damp cloth for best performance.
S. Mohan. Chennai, India
Fix scanner dr 7080c
Scanner issue
please clean the glass with wet tissue paper and see.
bye
old marine
old marine
ZJ Limited
ZJ Limited
