Question about KitchenAid KSRA22ILSS Side by Side Refrigerator
Kitchenaid KSRA22ILSS02 fridge won't get below 41 degrees
Freezer is fine, the fridge is the problem. Even if I set the digital thermostat as low as it will go (33 degrees), fridge stays at 41. I've moved things away from the fan at the top of the fridge, and I've dusted underneath the unit. I've experimented with different thermostat settings but nothing seems to change it.
Try shut down for overnight and turn back on next day. I had same problem - cooling air duct was blocked by ice
Posted on Nov 09, 2008
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Refrigerator temperature won't cool items lower than 41 degrees.I assume this is caused by a faulty thermostat.It is a Maytag Plus model MTB2156AE.
Not necessarily the themostat. It could be the internal fan that circulates the air from freezer to fridge or you have ice blocking the air flow.
Sep 13, 2011 | Maytag Refrigerators
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine but the fridge wont go below 10 degrees
Please check your thermostat and compressor. 1. Thermostat You need to set thermostat correctly. Put the set at middle or a bit colder. 2. Compressor. - You may have insufficient refrigerant - Low oil - Dirty evaporator.
Please observe both items above and get them fixed.
Dec 14, 2010 | Refrigerators
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
KitchenAid KSRA22ILSS Side by Side Refrigerator Logo
228 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
