Question about Acer Extensa 500T Notebook
Lost lex x4270 driver disk, trying to find dn load
As stand alone it works well but plug in usb port and starts to print and freezes
    Problem Solver:
  • 9 Answers
This is the link for the driver...:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0&os_group=WinXP&file_attachment_name=CJB4200EN.exe&dldiv=downloads/cpd&fileID=&searchLang=en&download=yes
Posted on Oct 08, 2008
What's your problem?How to unfreeze the Port 0 Disk Status in the setup utility for a Aspire 5251-1513?
If the issue is that it does not see the hard disk on the 0 port ...and it gives you blue screen memory error ..it means it does not have the ahci driver installed ..you need to instal it as a 3rd party ...or ..go to bios settings (press f2 on start ) .select the hdd and under the settings for it ..disable the ahci for sata ..and select ide or ide compatible ..or sata as ide..depending on choices..
save settings with F10 and restart ..It will make the port functional ..
If you want to install with the advanced host controller interface ..than press f6 I think ...when it asks for 3rd party driver ..and try to load it from a usb device by browsing for it ..(in normal mode you need a floppy drive ) ..but it may work ..be sure the usb is enabled in bios..
if it does not work ..than make a boot-able usb memory ..with the operation system ..and use it and insert the driver disk in the dvd drive ..and will work ..This way .when it asks for 3rd party drivers..you will load the raid driver and the ahci driver ..and go on with the installing ..
Dec 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
So i open my laptop. it shows the big dell sign and the bar loading. the bar always used to load for like a 30secs and now it takes like 2mins. after that the screen turns black and my computer freezes....
This could be caused by a couple of problems but you are going to need access to a second computer to determine the problem.
1) You have a disk that is failing and it has had an error. Got to the disk makers site and down load their diagnostic program and check the disk. This is a stand alone CD so you don't need to boot into the OS.
Another program that can temporarily fix errors is http://www.dposoft.net/ This program will stop after fixing the first error unless you buy it. Again, this is a stand alone.
If it is a disk error, you need to quickly get your data off and install a new disk.
Don't have a second computer? then you need to take it to a local computer store where they can remove the disk, install it in a desktop and check it for errors.
2) This could be a virus, but I think #1 is your problem. TrendMicro.com has a free online virus scan if you can install the disk in a second computer.
Aug 11, 2010 | Dell Latitude D600 Notebook
When i press the power button my computer turns on and after the dell loading screen it freezes completely if im fast enough i can press F2 F12 and even go to Safe mode screen but none of the options work...
Aug 11, 2010 | Dell Latitude 110L Notebook
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Apr 06, 2009 | HP Compaq nx6325 Notebook
Computer wont start-up
If I get you right, after you plug the xternal drive to transfer some file, the system didn't come up. Right?
Well, let me assume yes. If that is the case, I will advise you to boot the system from an external disk and use it to scan the local hard disk for virus. After that, remove the x-hard disk and try to boot the system. If it doesn't work, then transfer all the files to the xternal hard disk and format the local hard disk for new use. Best of luck.
Dec 14, 2008 | HP Compaq Presario V2000 Notebook
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
Toshiba SAatellite 100 Laptop
just update the motherboard driver cd again and try or else indivisually install the drivers from printer drivers
Dec 23, 2007 | Toshiba Satellite A100-S8111TD Notebook
Acer Extensa 500T Notebook Logo
Brian Sullivan
Brian Sullivan
