Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- N150X2-L01 (N150X2L01) CD-ROM Drive
Pioneer dvd-rw dvr-k17a
The drive is not recognized by the os, cant run any disc, i have checked in device manager it says;Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
I have a Toshiba A305 S6825 with a Pioneer DVD DVRKD08L ATA DVD player but no disc will work . When i go to device mgr it reads "windows (39) cannot install driver. WILL NOT WORK. ERROR CODE 37 I have the same issue with the Pioneer DVRKD08L drive in the Toshiba A305 I just purchased....help!
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Posted on Oct 15, 2008
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Pioneer dvd-rw dvr-k17 problem
dera ingrid 61
Please reinstall the drivers for the both of the problems,if you dont have any cd then plz visit the manufacture website and download the drivers, after installing the problem is not solved then plz try with another drive,if the problem persist then try by reinstalling the OS
Apr 25, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
Dear Sir/Madam,
This is the problem of not matching/support the motherboard of your driver with Pioneer DVD. U just go the manufacturing site of Pioneer dvd and download the driver / updates and then install it. (Before u uninstall the driver). Then fix it.
Thanks
"Don't Forget To Rate the Solution"
May 19, 2008 | Computers & Internet
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
Toshiba dvd burner problem
Try unistalling the dvd drive in device manager. Go to my computer click on view system information. Then click on hardware, then click on device manager find your dvd drive then right click and unistall a warning window will popup click ok. Once you unistall it restart the system and windows will find new device and reinstall the device driver. Then check if this fixes the problem. if this dosnt fix the problem try removing the dvd drive from the laptop and reinsert it. Sometimes the connection losses contact with the terminals.
Jan 19, 2008 | Toshiba Satellite A105 Notebook
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
1,305 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
