Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Frigidaire Chest Freezer Door Insulation smells like fish
This small freezer never has had any frozen fish stored. It has been cleaned but when we turn on power, it begins to have a fish odor which appears to emanate from the chest door insulation.
can the insulation and gasket be replaced and if so, what would the approximate cost be ?
Thank you.
dmbucks@gmail.com
    President:
  • 1,462 Answers
Might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Posted on Oct 08, 2008
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
How to fix a chest freezer seal
Hello friend, I appreciate your post!
I see you are trying to fix the seal on your Frigidaire chest freezer. Are you having an issue with your freezer not closing? If so, have you verified that there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body? Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. I hope this information helps. -Matt
Jul 22, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
What are the instructions for defrosting my upright frigidaire freezer and restarting and replacing frozen foods?
well when i used to have to climb into super market freezers and defrost we used water from the tap it doesn't have to be hot so i would take freezer outside to do this as it might not be drained and if it does have a drain it would only take a minute amount of water which an element would heat up and burn off so empty freezer take outside wash out with water till all gone and to get rid of any smells was out with vanilla essence all fridgies i know and myself used this as it will clean out fridge smells, you then replace freezer back once all water has dried off especially electrical try not to get wet but if you can't help it, it won't matter just let dry or blow out with air compressor then replace freezer back to where come from run freezer for a while till temperature drops below zero then start to restock the more you put in it the longer it'll take to freeze, so just do little by little hopefully this has helped but its usually the only way to do this
Nov 22, 2010 | Frigidaire Freezer Refrigeration White...
There is a horrible foul smelling fish like odor coming from the freezer. It has been cleaned inside and out and we found a dead mouse under the freezer but removed it and then cleaned again. There has...
This is just an idea. the sounds may just be age.. some systems are louder than others and some that are noisy become quiet. But the smell concerns me. It may be that there is something in the cooling fins that is producing the smell. The air from the outside does not directly go into the freezer so I don't think the mouse is the issue. Problems like this usually end up coming from the insulation inside the walls of the freezer. But since you have no history of the freezer loosing power and fish going bad I can suggest anything...If you have any easy access to the inside of the freezer try and take a look. One way to possible clean the smell is to put a bunch of charcoal briquettes on some cookie sheets and put those inside the freezer for a day or two. then switch them out... also you can put a pan of armor hammer backing powder down inside and change that every other day. good luck
Sep 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
There is a small hole in my g.e. chest freezer.
that is the drainage hole where water can pass out from .
Feb 18, 2010 | GE 7 cu. ft. Chest Freezer FCM7DR
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Fish smell
Hi there
i have to give that a wow !!! any way if you can get some clr and wipe it down real good and leave it wet it overnight that has helped us in some of the apartments that we clean well good luck and let me know how this does best regards mike
Feb 18, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
709 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
