Question about Garden
Power Tools Chain Saws igniton problems
I have a Husqvarna 61 serial no. 1611 110422. I have pulled the plug out and with the high tension wire connected, holding the plug against the cyl. head, turning the saw over with the recoil and there is no spark. I replaced the plug and still no spark.
The saw has good compression with the spark plug installed and there is no problem with fuel or air.
I need to know if the coils are the problem. I'm not sure how to test them or what the resistance values should be. The windings don't seem to be open because I get a reading of a certain ohms value (although I can't remember what they are right now). This model is an older one and has two coils installed on either side of the flywheel. One coil is connected to the On - Off switch and to the one side of the opposite coil. The other coil is connected to the spark plug lead and the other lead to the coil just mentioned.
I've done a little searching for parts. There are two different coil assemblies available from Husqvarna - Part No. 501516201 and Part No. 501516102. I'm not sure which one to use.
If you could help me sort this out I would be grateful.
Thank You,
Randy
Email - maggiedog@shaw.ca
  • 1 more comment
  • Anonymous Nov 29, 2008
    My Husqvarna model 350 chain saw has no spark with the plug removed and grounded. How do I test the ignition system to see if something must be replaced?
  • Zeplin Nov 29, 2008
    There is no spark available. How do I test the ignition system?
  • Anonymous Mar 16, 2009
    I have the same problem on the same model.  Did you get a solution to your problem?
  • 181 Answers
According to husqvarna the ignition coil is no longer avalible for this saw,the service bulliten says that every thing needs to be changed to make this saw work again.everything includes the flywheel,crank shaft,ignition coil,woodrif key,nut and washer.husquvarna will not let me order the origional coils.i do have a copy of the service bulliten if you would like a copy.just e mail me and i'll send one your way........
Posted on Feb 11, 2009
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Camaro 3.8 changed timing chain now no spark
CHECK POWER WIRE GOING TO THE IGNITON MODULE IT SHOULD BE BELOW THE COIL PACKS THE PLUG GOES BAD O N THEESE.
Dec 24, 2013 | Chevrolet Camaro Cars & Trucks
Cleaned spark plug on husqvarna 55 hard to pull cord wants to snap back help?
Most saws have a compression release valve which you press for that reason. It is located on the cylinder at the back of the saw. I don't know if the 55 has one , but it should.
Mar 19, 2012 | Husqvarna Chain Saw Models 51, 55
Decoding a serial number
I am pretty good but single year serials are beyond my expertise (black on silver or silver on black sn tag is one key). Husqvarna Contact Us: UShttp://www.husqvarna.com/us/homeowner/support/customer-support/ HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Looking at the availabl IPLs it could be 87 or 97. They will help with decode. Lets let the real experts help. LOL
HTH Lou
Feb 16, 2010 | Husqvarna Chain Saw 20" Bar
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Coil for an '86 Husqvarna 61 Chain saw?
Here you are. There are liable to be several others listed on this page as well.
Apr 14, 2009 | Husqvarna Chain Saw 20" Bar
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Power Tools
how many turns should be on the air and oil screws on the carb of the husqvarna c61 chain saw
Oct 08, 2008 | Garden
Garden Logo
652 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
