Back to:
Tags:
Accusys Acuta -DESKRAID Combo USB2.0/1394 IDE RAID OR SATA EXTERNAL Drive Case
Nokia IPSO 3.4.1 SSH Problem (I think)
By Bomber - usenet poster
Good Afternoon All,
I just upgraded my Lab Nokia from IPSO 3.3 to 3.4.1
and from Firewall-1 4.1 SP3 to 4.1 SP5.
In the process, while everything else seems to work fine,
SSH into the system fails.
I have identified that SSH was upgraded from F-Secure 1.3.6.1
to OpenSSH 2.1.1 and the auto-start of the SSH Daemon is
checked in the Voyager interface.
What I see is that the daemon process is not starting. Has
anyone else encountered this, and if so, how did you correct it?
Thanks!!!
Mike.
Michael Gaughan
Exelon BSC - IT Engineering
312-394-4527
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 26, 2006
Not Rated (0)
Duke
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks Kevin. I will try your recommendation soon.
Michael Gaughan
Michael Gaughan
Michael.Gaug@ExelonCorp.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Nokia IPSO 3.4.1 SSH Problem (I think):
I don't want to Accept this solution
Solution #2
Not Rated (0)
Peter1
Rating: 0%, 0 votes
Yup, should be in the release notes (although I don't think it is). The SSH
Demon is included in the IPSO 3.4.1 package now. You have to turn off (and
I think uninstall) the old SSH package *before* upgrading to 3.4.1.
Luckily I was building out a new box for a customer and it was blank to
start with. I just blew it out and started from scratch.
/ki
asi
Thank You!
Can you Help with these Drive Cases problems?
Drive Cases
I have a bytecc backupstar me-808 and the drivers will not...
Drive Cases
I need to remove the hard drive from a Maxtor personal...
Drive Cases
I forgot to mention that the old hard drive in the...
Drive Cases
i need to fit seagate hard diive into new enclosure
Drive Cases
the connector to the plug appears damaged, blue light...
Loading problems.
Repair Service
Find Drive Case Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
