Question about Whirlpool GD2SHGX Refrigerator
Whirpool Fridge Both Freezer and Fridge compartments stopped keeping optimum teperature. Freezer compartment is working as a fridge, and fridge also not keeping the tempeture as it should. Both temperature controls are on maximum (I actually tried many different combinations with no luck).
  • maxleilao Oct 08, 2008
    Frigde is a small 220 L Whirlpool. Couldn't find exact match in the available models here.
  • 750 Answers
Hello Maxleilao,
Welcome,
You said, Both Freezer and Fridge compartments stopped keeping optimum temperature. Freezer compartment is working as a fridge, and fridge also not keeping the temperature as it should. Both temperature controls are on maximum (I actually tried many different combination's with no luck).
What is the model #.
How old is it?
If the fridge is only a couple of years old , try turning it off and then! unpluging it for 5 minute and then
restarting it.
What happened?
if nothing good then most likely it is this next task!
It should be on a sticker inside the door jam or close to it on the inside wall of the fridge.
If it is real small like a counter high fridge, the number may be on the rear.
If the fridge is full size fridge check in the rear to locate where the condenser is. (lt looks like a thin row of black tubes that the freon travels through).
If not and they are under the fridge behind a removable plastic grille in the front of the fridge.
If this is the case then remove the plastic grille to see if the rows of thin (black tubes) called a condenser is covered with one to two inches of dust and not visable yet due to the blanket of dust!
This makes the condenser (black tubes) hot and unable to cool.
Air is sucked in from the front and passes over these tubes and cools the freon.
That is making it hot and the fridge and freezer warm.
You will need a flash light,
The plastic grille comes off when you press down on the top and up on the bottom together. Like squeezing the grille with your fingers until it comes off in your hands.
Get a flashlight, and get down on the floor and look under the fridge at the condenser. If all you see is an inch or two deep of lint and dust, then you need to buy a refrigerator brush at the hardware store and clean the thick coating of dust off.The brush is one inch wide and round with a very long handle 36 inches. Do this very slowly and gently. Remember the freon is in these tubes so you don't want to bend them and get a leak.
I know this was a long explanation but if this is the case I just saved you a service call.
It will take some hours to get cool again if this did not cause any damage to the compressor!
Some times all night till it reaches the max. temperature.
If there is no condenser below, or this does not do the trick, you may need to replace the thermostat!
or have a low freon level.
Waiting for your response
Let me know!
Huuum
Please remember to leave a rating at the end!
Posted on Oct 22, 2008
Temperature is not working either in the fidge or freezer please can you inform what gas is used?
Posted on Oct 23, 2008
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Ice maker quit working
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Oct 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ref in door ice not making ice
Sep 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Whirlpool GD2SHGX Refrigerator Logo
182 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
