Question about Panasonic TH-42PX60U Television
Black bar code lines on left side of screen a red line and multicolor line
I have had my TV less than 2 years already I hate this thing. I had the power board go bad first after that was fixed i got a APC power conditioner now I have 4 vertical lines 2 black like bar codes and a red line and a multicolor line. The volume bar looks different now as well.
Buy a samsung save yourself the problems. Panasonic customer service is terrible they are all nice till u get to the warranty then sorry we can't help you pay to fix it or but a new TV. I still have TV's that are 15 plus years old from college what is going on!!!
  • calakmul_5 Oct 23, 2008
    I also got a TH-52PX60U. My TV died and does not turn on. I got an error conde of 5 blinking lights and a pause.
    I called Panasonic Customer service and they refered me to several local repair services. I found out that it is almost as expensive to repair my unit than to buy a new one.
    Of course I'm out of warranty. I though that I will get a TV that will last at least 5 years but here I am. 1 1/2 years after I bought it.
    Any idea on what I need to do to repair it? I don't want to call a service and spend a ton of money if there's something I can do.
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
  • 10 Answers
chake to make sure it is hooked up right and not lose
Posted on Feb 02, 2009
Dissolu
  • 221 Answers
SOURCE: Black vertical column
for your reference regarding black vertical lines
http://www.metacafe.com/watch/3009132/video/R/CFD_1002/
Posted on Jun 29, 2009
  • 380 Answers
SOURCE: solid black vertical line
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable2_bing.gif and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
Posted on Dec 06, 2009
My flat screen tv has a multicolor bar running down the middle from top to bottom, how do I fix this?
you can fix it by going to tv colour changing option otherwise you read the catalogue.
Mar 27, 2013 | Insignia NS-24E730A12 24" Class LED HDTV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
Hello i have a black line runnig across my screen horizontally. Some times disapperar for a few seconds and tv is normal and then comes back. Some tines is black and some times l flashes in red, ...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELPOUT IN SOLVING THE PROBLEM...
May 18, 2011 | Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic TH-42PX60U Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
