63 inch Phillips Plasma intermittantly won't turn on until power is pulled from unit and you can here what sounds like a relay resetting.
Went to Phillips and found a firmware update for this problem. Appears to have resolved problem.
Posted on Oct 08, 2008
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Samsung 63 inch plasma sound no picture
This problem isn't a capacitor issue .Its a Y-sus issue or a panel issue
you need advanced help to solve this .
Jun 24, 2014 | LG RU-42PX10 42 in. HD-Ready Plasma...
My 50 inch phillips plasma made a loud pop and the picture and sound went away. if i plug it in it makes the normal click a few times and the green light comes on and then flashes red.
I have the same problem. after pulling the back off. we found that the 3 capaciters above the 2 power relay switches are bad. i am currently looking for a scematic so i can replace the 2 dios that burned up due to the issue along with the capasitors.
Dec 08, 2010 | Philips 50PFP5332D 50 in. Plasma...
50 inch plasma phillips won't turn on repeated clicking noise
This is likely the relay that connects the AC to the main power supply although in a plasma TV it could indicate a failure of the high voltage power supply for the display itself.
Turning on most sets causes a small power supply for the infrared remote receiver to connect the main power supply to AC. If the power supply itself is defective, the relay interrupts or if the supply is still healthy, it may disconnect the AC again to prevent damage to the main supply and possibly a fire.
Since there are two primary sources for this problem and no good way to separate them as the faulty part, you will need a tech to be on site to determine exactly which failure has occurred.
Sep 06, 2010 | Philips 50PFP5332D 50 in. Plasma...
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
I have a Phillips 42 inch Plasma. I tried
One of two issues/problems:
1) Main Power supply problem
2) High Voltage Power supply problem.
A Good TV Service Shop that works on Philips would be the first place I'd call. It will be much cheaper to bring the TV into the shop instead of having a tech come out to your location.
Possibly a $200 to 300 dollar repair.
A/V Media Guy
Nov 23, 2009 | Televison & Video
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
