Question about Sharp R-1510 Microwave Oven
Display window doesn't show anything
The display window on my microwave doesn't show anything. It's just black. The other buttons seem to work ok. Thanks.
  • Anonymous May 20, 2009
    display window is black, microwave works but no display at all
  • Sharp Master
  • 9,086 Answers
The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
The repair service saves you a lot over the cost of a new control unit and comes with a full year's guarantee.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 08, 2008
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
Bare ile bo100 microwave won't go keypads seem to be ceased lights ok on display pls help
You can try unplugging the oven for at least 15 minutes to see if the control panel will reset on its own.
If that doesn't fix it, you might have a bad control panel, or oven may not be properly grounded.
Oct 02, 2016 | Microwave Ovens
Microwave turns on but keypad doesn't respond.
If it's brand new it should easily be returned to the manufacturer (Or retail outlet) So dont worry, Just take it back tell them your problem,. They'll probably be happy to help, This is a situation where you can do little if anything and are probably facing a defective product
Dec 02, 2013 | Bosch 800 HMB80 1000 Watts Microwave Oven
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The microwave doesn't work at all. no display, light, anything
Plug a lamp in the wall receptical in place of the microwave oven, if okay! it means the main fuse in the oven has blown. There are a number of reasons why this happens, a bad fuse, door switch that has malfunctioned, "common" cracked high voltage diode, shorted capacitor, and an open magnetron. I suggest a professional.
Mar 09, 2012 | Panasonic Microwave Ovens
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I have owned a AMC5101AAW for about three and a half years. It has been a good microwave,perfect for my needs. The display went black and the buttons didn't work right after I boiled a cup of water for...
It sounds like it could be just a bad crimp connector supplying power to the whole system, which would have to be the fuse holder on the mains input panel.
Worth a look!
Jan 01, 2011 | Amana AMC5101AAS Stainless Steel 1000...
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
Sharp R-1510 Microwave Oven Logo
286 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
