Question about Samsung LT-P578W 57 in. LCD Television
Verticle lines on screen
Has lot of black verticle lines across screen
  • wwjd20001 Oct 08, 2008
    maybe i didnt tell u the correct tv i have its a 52 inch hdtv lcd samsung
    does this make a difference
    Scholar:
  • 116 Answers
Its the ic problem.on the board.
Posted on Oct 08, 2008
  • 3 more comments
  • mastermind10 Oct 08, 2008
    It depends where the line is centered most, to the right or left of the center, there are buffer boards that control the vertical video, on the bottom part of the unit if you take the back off and look at the bottom part of the set you will see these address boards, they are usually about 2 inches wide and could be labeled J or K, if the unit is High Definition then you could have these buffer boards on the top part of the unit also
    it also happens if The Graphics Card is broken or cracked.
    You must have a CRT. What happened is that the vertical deflection circuitry has gone out or the yoke has failed. You see this line because the gun isn't scanning the sceen to paint a moving picture. Instead, it's just tracing back and forth in one spot. I have some clue about this because it was one of the most classic problems back in the fifties and sixties, usually indicating the need for a new electron valve or two. The problem still crops up, but transistor's reliability have made it rare enough that the average younger TV owner hasn't heard of it.
    also try this before reparing.
    try disconnecting it from the wall for 15 minutes, disconnect all inputs, then plug it back in - do not reconnect any inputs. Turn it on and see if the line is still there. If yes, then off to the store you go knowing its a fault in the guts of the unit. If no, then reconnect the TV input and see. If it reappears then the fault is the signal not the TV.
    you can try.
    hope it works......
Jumping lines throughout the screen affecting quality of picture
You didn't say weather the lines are verticle or horizontal, but if the lines are verticle check the circuit for a weak capacitor or if the lines are check the horizontal circuit for a weak capacitor. During your check check for cold solder joints, idf you come across ant re-solder then. Good luck.
Jan 27, 2011 | Pioneer PRO-520HD 53" Rear Projection...
I have a HL-R5067W Dlp. Turned it on and have verticle black lines. Eight lines then 1 1/2" space then Eight lines repeated across complete screen.
It sounds that dlp chip got defective and need to be replaced to fix the lines issue. Local tv repairman will help you to get it replaced if you do not have experience of tv repair.
Hope this info will help you.
Thanks.
Jul 07, 2010 | Televison & Video
Verticle lines across top of screen
This is a problem with the vertical circuit and because it "repairs" itself, sounds like either a poor solder connection or a failing capacitor. This is a fairly common problem that is easily resolved. If you have repair experience, you can fix this yourself. Please verify the model number and whether or not you plan on attempting the repair and I'll supply additional details.
Thanks,
Dan
Jun 11, 2010 | Daewoo DTQ-25S2FC 25" TV
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
Verticle lines on the screen
Failing Display Panel Circuit Board... THis Means You Will Need A Screen Replacement..
Nov 17, 2009 | Toshiba Satellite A105 Notebook
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung LT-P578W 57 in. LCD Television Logo
182 people viewed this question
Henry  Thomas
Henry Thomas
