Hi: My printer is a older one but works very well. It is HP 990C we have a new hard drive & it only has USB ports. If there any solution to this. Diane
    Genius:
  • 1,913 Answers
U hacve to pur chase usb to parrallel conveter .
many converter sell in market purchase them.
Posted on Oct 08, 2008
How to print envelopes
Go to control panel on the computer Go to printers and faxes or printers Click on add a printer Select 'Add a local printer' and click on Next Use existing prot is already selected and next to that there is a drop down, from the drop down select virtual printer port or USB port (Usb0001...) Click on next, and on the next window; In manufaturer's box select Hp and in Printers box select Deskjet 990c Then keep clicking next and at last finish Try to print any test page and then try to print envelope Note: 1. Hp Deskjet 990c is the universal driver for all hp printers 2. This work around only works in the case of Windows Xp and Windows Vista not in Windows 7 3. In windows 7, instead of Deskjet 990c, we can use Deskjet 9800
Oct 27, 2010 | HP PSC 1610 All-In-One InkJet Printer
My color when I am printing photos on high quality photo paper is dark?
Try to add your printer manually with the generic driver Deskjet 990C, please perform the given below steps :
First connect the USB cable between the computer and printer.
1) Click on startà control panelàprinter and faxes.
2) Click on Add a Printer option on the left side and once you click on it a new window appears, click next
3) Select Local Printer and uncheck the automatic detect and install my plug and play printer option then click next.
4) Now select port that says USB Virtual Printer Port and click next
5) After that under Manufacturer option select HP and under Printers option select Deskjet 990C and click next.
6) Now name the printer as Deskjet 990C and set it as default printer and click next.
7) After that select Do not share this printer and click next.
) Now select No for print test page and then click on Finish and then try to print photo and check.
If your issue gets fixed, please come again to give us a
vote which will really motivate me to help people in
future.
May 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a HP Psc 2355 All-In-One InkJet Printer Bottom of page is cut off sometimes printing from vista computer
USB Cable Connection:
=== HP Deskjet 990c Drivers on Vista ===
* Click on the Windows button.
* Type 'Printers' without the quotes and press enter.
* In Printer folder, click 'Add a printer' button on top.
* Click on the option 'Add a local Printer'.
* Put a check mark beside 'Use an existing port' and choose DOT4_001 or USB001 or USB002 from the drop down box.
* Click on next.
* Choose 'HP' from the list of manufacturers and 'HP Deskjet 990c'from the list of printer.
* Click on next.
* Follow the onscreen instructions to configure the drivers.
NOTE: While printing, please choose the all-in-one as HP Deskjet 990c all-in-one and then try printing
Network printer:
* Put a check mark beside 'Use an existing port' and choose TCP/IP from the drop down box.
* Click on next.
* Click on next.
Oct 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My HP psc 750 won't print. I just get blank pages.
Try This:
Click on start
Goto to control panel
Goto Printers and Faxes
Click on File
Select Local Printer Attached to this Computer
then select LPT : Port 1
Then select have disk ;
Right navigation bar select Hp
And in right select Deskjet 990c
Install the driver and finish the installation
even after that it doesn't prints
Then right on the printer icon (Deskjet 990c)
Click on properties
Click on the port tab
Select the Virtual USB port
Then try to print;
Otherwise reinstall the software from the downloaded version
Regards Soumajit
Sep 16, 2009 | HP PSC 750 All-In-One InkJet Printer
Inabilityy to print from QUicken 2008 under Vista 64-bit OS
I can only speak for my situation, which is Windows Vista Home Premium 64 bit with a HP7590 all in one printer. I had all the problems I read about, note I was only interested in printing "reports" from QUICKEN 2008 DELUXE.
I was able to use the Quicken PDF printer, but I just installed the HP 990C printer drive and found that report printing now works. I did delete the PDF printer before I installed the 990C, but I would guess that's not necessary.
HP considers the 990C a "generic" printer.
Hope this helps.
Aug 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Usb ports (HP Pavilion dv2000 Laptop) unable to retreive data
NO OS STATE is this the XP virus maget , dead for 3 years now?
XP does not work on many USB devices even after the SP3 update
and THE SP3 UPDATE is mandatory. service pack 3
DV2000
id bet you if you booted to linux CD, (knoppix 7 live)
all usb ports work, telling you what, in seconds, XP IS DEAD.
for a fact.
google XP USB dead, (billions of hits for 16 long years)
MS dont support this OS nor VISTA or older.
HP does not support DV200o now its legacy hardware now.
MS plug and play is dead too on XP. per there warnings.
The means all new XP things will be dead, if the maker of said things
does not give you Their soft or that thing..
if hell bent on using XP ,(why) upgrade to W7
then get SP3 there.
https://www.microsoft.com/en-us/download/details.aspx?id=55245
it came new with XP
and was VISTA READY, best is to go W7. !
Goodwill store has $20 laptops with W7 on it working now.
why wait, dump yours, and UPGRADE HW/SW all at once
and WIN.
why to not RUN XP (endless bad and advancing....)
http://www.pcdied.com/XP-sux-sg.html
Aug 02, 2017 | HP GbE2c Layer2/3 Ethernet Blade Switch...
HP1320 Printing on both sides problem
Try this -- it worked on my HP Office Jet 7310xi --
1) Control Panel -- Printers
2) Click on Add Printer
3) Add a local Printer
4) Click on "Use Existing Port" then choose "USB 001..." Then Click NEXT
5) Choose HP from Manufacturer Then choose HP 990c. Then Click Next
6) This will install the drivers and make the 990c the default printer. Use this printer as your default and choose the Print on Both Sides option. It works for my 7310xi. Good luck.
Feb 02, 2009 | HP LaserJet 1320 Printer
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the...
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Mar 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
46 people viewed this question
jasbo
jasbo
