Question about Sony PlayStation Portable (PSP) Console
Psp green wireless lan light stays on all the time even when not using wirelessly
  • wlessman Oct 08, 2008
    I tried turning the switch off but it still stays on.
    Problem Solver:
  • 13 Answers
Your switch probably is broken or has bad contact. Normally the WiFi function should go off immediately as you turn off the switch. You should let your PSP checked by Sony if it's still under warranty or let someone who can work with PSP hardware fix it for you.
Posted on Oct 08, 2008
  • 41 Answers
There is a switch on the PSP that turns the function on and off.
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
Light problems
I wonder if your 'Active Wireless LAN' checkbox, found under 'Network > Wireless LAN > General Wireless LAN tab' is really checked. If so, and yet, your router doesn't broadcast, then I suppose its hardware is faulty.
Just my 2 cents... Carlos
May 17, 2010 | Zyxel P660HW-D1 Router
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Wireless capability switch not working
Same problem... It's just that I don't even get the light glowing as internet is on on the start...
Apr 04, 2009 | Acer Aspire 5570-2758 Notebook
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Network switch
Sounds like you know what you're doing... but.. based on what you've typed..
You need to make certain the comcast cable modem is plugged into the seperate port on the back of the router called WAN and not next to the other LAN connectors.
The network is seperate from the internet. The router acts as a firewall and shares the WAN with the LAN internally and automatically.
I assum that you have one red light on WAN.. and three green lights for LAN..
Jun 18, 2008 | Arris Wireless G Broadband Router (wr850g)
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
2wire 2700 HG - Many problems and can't reset it!
you need to set up the 2 wire using an RJ45 ethernet cable and not wirelessly initially, and you need to set your ethernet lan adapter to obtain an ip address automatically and then type the default 192.168.1.254 in your browser to get in the settings and then set or enable dhcp, and also enable wireless as by default it is dissabled and check the the adsl light is lit
Some 2wire routers normally come with WPA-PSK security already set up with the passkey on a sticker on the side of the router, so that may be why it stays set when you reset it.
Check that your wireles adapter is using the same type of security when you enter the passkey when wirelessly connecting.
Nov 21, 2007 | 2wire 2700HG-B Router (2700HGB)
Sony PlayStation Portable (PSP) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
