Question about LG LHD45EL Dehumidifier
LG LHD45EL The full light blinks and the unit wll not start, even though the bucket is not full. I have made sure the switch is working and the float is free. I have the following showing in the HUMIDITY SETTING display: CH 01 I have cleaned the filter and the coil is spotless. Any suggestions?? Craig Kent Westerville, Ohio
  • 1 more comment
  • souponthego Oct 26, 2008
    My LG LHD45EL has stopped working. The display reads CH 01. The "Bucket Full" light blinks every 3 seconds. The bucket is bone dry. I unplugged it for a few minutes, plugged back in. Fan engaged for about 3 seconds, display read "on", and then it went back to CH 01 and shut down with "Bucket Full" blinking again.
  • rneilsonm1 Oct 28, 2008
    The bucket is empty. I have also cleaned the filter and CH 01 keeps appearing. I turn it on, it runs for a second or two....and CH 01 keeps showing up.
  • Anonymous Jan 26, 2009
    same problem after 30 days
  • 3 Answers
The temperature sensor on teh suction return line from the coil has drifted out of spec and needs to be replaced. This sensor is part of the sensor assembly which plugs into the control board. I purchased the part from Appliance Factory Parts on line, cost about $30, an hour or 2 to change depending on your mechanical level, it is easy to do. For Goldstar DH404E part # was 6877A30013M, they are same part for many models but if this is not the right # for your model just get the right "sensor assembly" for your model and change it out. It consists of Temp/humidy sensor in coil, temp sensor in suction return line, and plug harness that goes to float switch. My uni is running like new again.
Posted on Dec 16, 2008
Emptied bucket fine. Went to turn back on starts to work and then shuts down right away
Make sure that the water full detection switch is not stuck in the full position. Its a plastic piece near the top side and when the water level gets high enough it floats the piece up to turn off the unit. It can sometimes get misaligned when changing the bucket and stuck in the off position.
Feb 05, 2014 | LG LHD45EL Dehumidifier
The "bucket full" light blinks even after the
Eddie, turn the unit OFF & unplug it. Then remove the bucket and check the float valve in the top of the bucket. It may be stuck in the 'UP' position or is broken. When reinstalling the the bucket, be sure that it fit's "squarely" from top to bottom in the bucket holder and is making firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | LG LHD65EBL Dehumidifier
Bucket full light blinks with display code of 01 when bucket is empty
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 28, 2011 | LG LHD45EL Dehumidifier
MY LG MODEL # LD450EAL HAS THE FULL BUCKET LIGHT BLINKING AND THE BUCKET IS EMPTY AND HAS BEEN CHECKED TO MAKE SURE THAT IT HAS BEEN REINSTALLED PROPERLY BUT IT STILL DOES NOT STOP BLINKING AND THE UNIT...
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall. Remove the bucket and check inside the top of the bucket for a Float Valve (some Haier unit have them) It may be stuck in the UP position. If so, jiggle the arm of the float vale to get it to return to the DOWN position. Reinstall the bucket again. However, leave the unit OFF & unplugged for 10 minutes, before plugging it back in and turning it ON. Whether you have a float valve of not, the 10 minute time out, should have given the unit's electronics time to reset themselves.
Hope this helped you troubleshoot and solve the problem.
Jun 25, 2011 | Dehumidifiers
Our LG LHD45EL dehumidifier stopped working. The bucket full light flashes, though the bucket is empty and the filters clean. The display shows CH01. The manual does not say what CH01 means. Any...
I don't know what CHO1 is either! My husband and I had the same problem a couple years ago. We just ended up buying a new one.
http://www.donmurraysbobcatandtipperhire.com.au
Jul 22, 2010 | LG LHD45EL Dehumidifier
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
The bucket full light is on and unit will not run. Unit has hose adapter in use.
Look inside where the bucket goes in at the top right hand side is the bucket switch. Hold it in and start the unit. If it runs the arm on the switch must be bent SLIGHTLY until it makes contact with the button and the lite goes out with the bucket in.
Nov 16, 2009 | LG LHD45EL Dehumidifier
My LG dehumidifier does not turnoff when full and overflows
make sure the float in the bucket isn't binding on something. The float actually activates a button that you can see when you remove the bucket. pull the bucket out and see if the unit cuts off. Maybe the button is stuck.
Aug 11, 2009 | LG LHD45EL Dehumidifier
LG LHD45EL Dehumidifier Logo
1,325 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
