Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
MAG innovision 900w 19" LCD flat panel
Hello, I can see the images when I turn on the lamp in my room, not clearly but some dull images...and can tell what's on the screen. So I assume the problem is with the lamp inside the screen. You told on the post earlier to fix about the screen going blank on this flat monitor but you didn't specify how to replace the lamp inside. Like How do I do it, if I want to do it myself? My email is: mbillyh14@gmail.com
Thanks in advance!
Billy
  • Anonymous Feb 17, 2009
    I have a 17" Proview model 900W and it shuts off after turned on for less than a minute. But the picture is great when I turn it on. What could be the problem and does anyone have any pictures of how to replace the bulbs or inverter?
    Champion:
  • 293 Answers
Hi..there,
Well, you need replaced a new backlight inverter. if you got a AC Adapter with this monitor. The backlight inverter it to your left a small rectangle piece. Monitor without AC Adapter, the inverter it to your right... it's a large piece of power supply w/ buit-in inverter. OK! Wanna repaired it yourself...
First of all, inspecting the inverter closely...if you're lucky you can see a over-heated capicators with a bulged caps on top. Those caps need to be replaced. if you're not sure....just replaced all the caps.
Good lucks! Have a nice day!
Posted on Oct 08, 2008
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: MAG Innovision 900w flat screen... how to?
This is a common problem due to capacitors in the inverter circuit going bad. The inverter provides the voltage to light the backlight, so the lamp is usually not the problem.
If you open the case on the monitor (sometimes that's a challenge all by itself) and follow the wires from the backlight to the circuit board, you'll find the inverter circuit. There are normally a couple of transformers (they may be small square cases or round coils of wire on black or gray forms), some transistors, and the infamous capacitors. The caps are small cylinders with printed values on them, like 4.7uf, and also a voltage rating. Most of these are values you can find at Radio Shack, so if you or someone you know has soldering experience, you can try changing them. Stick with the original capacitance value (the uf number), but try to get a slightly higher voltage rating if you can. The voltage ratings come in standard values, like 16 volts, 25 volts, etc. The higher voltage parts will be a little bigger but should still fit. They go bad because the rating wasn't high enough to begin with. But it saves the manufacturer a little money on each unit. Make sure you observe the polarity of the capacitor (plus and minus, with some kind of marking on the circuit board to show you) when you put in the new ones.
Posted on Dec 06, 2008
I have a mag innovision moniter flat panel butno power supply and can't find where one would even be on it
It took me an hour to find it. It should be on the cord that connects to the hard drive. At the bottom on the blue part.
Dec 12, 2010 | Mag Innovision LT976S 19" Flat Panel LCD...
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
How to disassemble Mag innovision 19" monitor
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
Feb 27, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Black screen
It is most likely that the filter capacitors on the power inverter board have failed. I took mine apart and found seven swollen capacitors on the this board, they fail prematurely and seem to be the only thing wrong with the unit. I replaced them and now it is working just fine.
six 470uf 25v electrolytic capacitors and one 220uf 25v Capacitor.
you should not attempt to repair this yourself unless you have some electronics training since there is a shock hazzard involved and also these capacitors will blow apart if they are installed incorrectly (very messy experience).
Jan 31, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Oct 05, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision 19" TFT LCD Flat Panel Monitor
the monitor has bad backlights or circuitry. Call the company, their number should be in the owners manual. Or, look on the web for their website. Or, call the store where you bought it. The monitor must be taken to a service centre for repair.
Mar 26, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Computers & Internet Logo
2,265 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
