Question about Apple iPod touch
Ipod touch 32 gb screen
my ipod touch 32 gb is freeze the only thing that appears on the screen is a bright white light . i have tryied almost every thing . i hope somebody can help me out there.
    Problem Solver:
  • 8 Answers
What you need to do is restore it, i have had the same problem b4, it is right now in recoverymode, meaning it has no softawre on it, so restore it in i tunes, if it dosent recognise the ipod restore holding shift with a firmware you can download
Posted on Oct 18, 2008
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
How do i upgrade the iOs on iPod touch 3rd generation MC086LL
The 32 GB and 64 GB configurations of the iPod touch 3rd Generation are only supported by the last version of iOS 5. They are not supported running iOS 6 or subsequent versions of the operating system.
The 8 GB configuration is not even supported by iOS 5.
iPod touch 3rd Gen 32 64 GB 32 GB 64 GB Specs 3rd Gen Late 2009 A1318...
upgrade-ios-ipod-touch-3rd-generation-ucocffsbdgqp14shduy2nfxr-3-0.jpg upgrade-ios-ipod-touch-3rd-generation-ucocffsbdgqp14shduy2nfxr-3-2.jpg
Nov 30, 2012 | Apple iPod touch 3rd Generation MC086LL/A...
Ipod touch stuck on white screen and i cant restore
Hi connect it to wall charger and charge it then connect it to pc and boot in dfu mode, if you don't know how google for it then start iTunes and restore.
Oct 07, 2012 | Apple Ipod Touch 4th Gen 32 Gb, Nice...
Ipod touch 3g has a white screen - any way to bring it back up?
Hi mickhon...
White Screen of Death
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Sep 17, 2011 | Apple Ipod Touch 8 GB 32 GB 64 GB 3rd...
I got my ipod touch wet with water, an my touch screen stopped working.then i blew in it where u charge it an te screen turned white so i let it dry an now the touchscreen wont work an its like really...
Throw it in a bag of white rice for a 5 days. Restaurants use it in their salt shakers to absorb moisture.
Apple won't replace units damaged by water, but theres a guy on You Tube that will show you ways to defeat the system so you can trade in your ipod under warranty for a new one.
Cheers Old Chap.
Feb 24, 2010 | Apple iPod touch
My Ipod Screen Went White And Now It Wont Turn On, How Do I Fix It?
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Dec 05, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
Ok so my ipod woks perfect but the light is not i tryied going to brighness but its not working
try turning the " AUTO-BRIGHTNESS " on. then boost the light up or down.. if that doesn't work send it to apple.
Oct 27, 2009 | Apple iPod touch
I can't sync my IPod 80MG since downloading the newfangled iTunes9!
I never heard of Apple putting out a 80 MG ipod touch. You must have one of those cheap China knock offs. The ipod touch comes in three flavors- 8, 16, and 32 GB
If you got an ipod classic 80 GB, then hold the center and Menu button same time until the Apple logo appears.  This will reset the thing for you and you can try re-syncing.  Otherwise, uninstall itunes 9 and go back to the update that was working.  Just cause its a new update doesn't mean you gotta install it.  If your system works, then don't fu.k with it.
Oct 22, 2009 | Apple iPod touch
Apple iPod touch Logo
270 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
