Question about Sony Cyber-shot DSC-S730 Digital Camera
Nikon D40X quit working - memory card access lamp flashing??
Camera was working fine, removed battery and charged, reinserted battery, turned camera on. Memory card access lamp is flashing every couple of seconds when camera turned on, and for awhile after camera turned off. Nothing else is working (no display, nothing). Took it to the camera shop and battery is fine. I routinely delete phots so memory card is empty or only has 30-50 pictures. Camera is about a year old. Any ideas?
  • 27 Answers
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
My Nikon D3100 will not turn on. Is there something wrong with the batteries/memory card? Or rather the camera body itself?
It could be either the battery or the camera.
If you have a second battery, try it. If it works with the second battery then the first battery is bad.
If you don't have a second battery, take your camera and battery to a good photo store. They should have a second battery to try. You might be able to test your battery with one of theirs. This will tell you whether the battery or the camera is bad.
Oct 04, 2016 | Nikon D3100 Digital Camera
CONSTANT FLASHING CF LAMP NIKON D300
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Nikon D40X Digital SLR Camera Digital...
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Memory card access lamp flashes and Nikon D40X camera does not come on.
try a different SD card. or try formatting it on a PC with card reader.
Dec 28, 2009 | Nikon D40x Digital Camera
Same Problem
Could be battery contacts. Take a pencil with an eraser. Gently rub the battery contacts both inside the camera and on the battery itself. Install the battery and try it. Best of luck.
Jun 11, 2009 | Nikon D40x Digital Camera
My D40X won't turn on!
It is required to solder a main pcb.
Dec 05, 2008 | Nikon D40x Digital Camera
Camera will not turn on
Check lens contact. Remove lens, clean contacts, but them back and try again.
Nov 22, 2008 | Nikon D700 Digital Camera
Memory access lamp flashes
WHEN POUTTING INN A MEMORY CARD ON NIKON DSLR CAMERAS THE GREEN LIGHT WILL BLINK ONE TIME .
IF IT CONTINUES TO BLINK THE CARD COULD BE BAD AND TRY TO FORMAT IT .
ALSO YOU COULD HAVE A BAD COMPRESSION BOARD.
Oct 29, 2008 | Nikon D70s Digital Camera
Nikon D40x
reset everything, including removing the lens, battery and memory card. small reset button on side, reset icons on screen.
works beautifully now!
Aug 20, 2008 | Nikon D40x Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
216 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
