Question about HP vs15 15"LCD Flat Panel Monitor
HP pavilion VF15 moitor
I have a HP pavilion VF15 monitor the screen blinks but i can still see all my desktop icons what can i do to fix the problem
  • 5 more comments
  • sltwins Oct 13, 2008
    It strobes, blinks, and usually goes back to normal.
  • Iowa Walker Nov 06, 2008
    Upon turning the monitor on, from either being off or from being in standby, the screen will blink on briefly then turn off and cycle through the same pattern for anywhere from 2 to 10 minutes, after which point it functions normally.
  • lhow Jan 10, 2009
    Same monitor and problem, it just flashes and you can see the desk top icons for half of a second.
  • meuw35 Mar 09, 2009
    my monitor is flickering, if I hold the screen and press my thumb lightly on the screen it stops, I have a hp laptop dv5000, everthing else is working, but the screen iis aggitating me...is it loose? hhow do i tighten it?
  • Anonymous Apr 30, 2009
    when i power the moitor it blinks, for only about 2 seconds and the goes to sleep.
  • wesstrader20
    wesstrader20 Oct 02, 2012
    my monitor for the past few months,when u just turn on the mointor it will work fine but once u turn on the computer, the monitor will turn off then on and will continue until u cut off the computer. i can still log in and do everything between the moniter power flashes. what can i do to fix it?
  • Anonymous Mar 27, 2014
    When I try to see desktop icons after the monitor has been unused for awhile, it only shows taskbar and screensaver and not desktop icons. The
  • 3 Answers
Replace 4 dead 470uf 16v capacitors and 1 1000uf 16v capacitor on power in circuit board. worked for me.
Posted on Nov 19, 2008
I don't see any solution. can you tell me the solution please.
Posted on Oct 16, 2008
My moitor is powered up but the screen is showing black. I can see very very faint words.what is the problem
chect your bright and contrast controls if they are ok
replace the cold cathode tube power inverter circuit board; it's under the center bottom of your monitor screen
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
I have the HP Pavilion dv2890NR Artist Edition. At first the screen went fuzzy with green streams of numbers and letters, it would then go black and if i turned it off and back on again it would work....
Actually, the fact that the laptop is booting and you can hear the Windows sounds is a very good omen.
1. Get access to an external monitor
2. Connect to the monitor, power on the laptop, and hold down the fn key and press the F4 key to transfer the video signal to the external monitor.
3. If the external monitor looks like your normal desktop then you only need to replace the screen and screen inverter.
4. If the external moitor will not display your laptop's signal, it's a more serious problem and would likely demand a new motherboard.
Knowing the outcome of the test will help you choose which action to take. The scrren and inverter replacement should cost about 150 to 175 US if you find someone nice whose not trying to rob you blind. :)
Aug 23, 2010 | HP Pavilion dv2890NR Notebook
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
HP Pavillion vf15 Monitor flashes off and on rapidly
sounds like the cable is out but i dont know how to fix it srry
Mar 26, 2009 | Computers & Internet
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
HP vs15 15"LCD Flat Panel Monitor Logo
559 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
