Some channels have sound, others don't - Televison & Video
  • 520 Answers
Check to make sure the SAP is off.
Posted on Oct 08, 2008
Why is there no sound on itv on my linsar tv? How can I get sound?
un mute it, sum tv's require an external tuner for sound. if you don not have a built in tuner go back to the house you took it from and get the rest of the parts you unpaged.
Apr 12, 2015 | Linsar Televison & Video
Onkyo sv545 one channel preout don't work
If you feel it is , here's the components to check:
Check Q444 (muting transistor)
Q407
Q403 ( TC9213P), Q371
Q402
Oct 09, 2012 | Onkyo TX-SV545 Receiver
My toshiba 32DTIU has sound but no video
The "Toshiba 32DT1U" is a 32" class 720p 60Hz LCD TV.
Other than checking the connections, and making sure that you don't have a headphone port with a cable plugged into it,
I don't think there is much consumers can do with recent date manufactured LCD TVs, as far as repairs go.
Hopefully helpful,
sl0j0n.
Jul 26, 2012 | Computers & Internet
I recently got a JL 300 amp and at first the sub stopped working, then it came back on during the song I was playing. Later on it shut off all together. I don't know what the problem is..
Does it only happen on that channel. It is a 4 channel amp so make sure the other channels are working. It sounds like an RCA input prob. Try the sub on the other channel. if it works then it would be your RCA input needs resoldered.
Sep 04, 2011 | Jl Audio 300/4 Car Audio Amplifier
I had comcast before but now i don't ,don't use a converter box and somehow I was getting cinemax and other channes on the tv,now i am not I auto programmmed the tv again and mess the the channels...
> I had comcast before but now i don't, don't use a converter box and somehow I was getting cinemax and other channels on the tv
Comcast was providing Cinemax and many other channels as part of your paid services and you will not receive these unless you are a subscriber. There is a good selection of free broadcast channels unless you live outside city areas. If you do, you will then need an external antenna and probably an amplifier to get more distant signals. Auto programming will not find the channels you were receiving from Comcast so there will be only accidental channel duplication; for example, if your former channel 10 was NBC, it may be channel 7 when receiving signal from an antenna.
There are essentially no more 'Analog' stations still broadcasting, they are now all 'Digital.' The abbreviations 'Std' refers to the aspect ratio (H/W) of the picture area and 'Hrc' and 'Irc' the available resolution or how many pixels and lines on the screen.
Aug 28, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I have not received a diagram of my stylus wiring. none of the sites that was recommended have helped. do you know the purpose of each color of the four wires?
One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
Jul 30, 2011 | Audio Players & Recorders
I just picked up a 99 china cobra ltd st. Tx works on all channels, but no Rx on channels 1-19. Any help pointing me in the right direction would be greatly appreciated.
somebody tampered with internal adjustors seems to me. you can take a screw driver and turn off receive for so many channels but crank it for higher band. It was probably locked on a upper channel for a Friendly chat station say Channel #28. Where they stayed and talked on 1 channel all time. Could be that. Maybe its got broke wires or board on that other set of channels or parts fried, chip bad etc. Get it checked out at CB shop. if you have any knowledge, turn IF to receive and crank up receive inside radio. If don't know anything take to shop..sounds like simple fix to me.
Feb 18, 2011 | Cobra 29 LTD CB Radio
No sound on some channels, some channels have wrong sound for pic
The SAP feature has been turned on. Look for a button that says SAP or go thru the audio menu and turn it off.
Apr 09, 2009 | Televison & Video
My Motorola MA580 sometimes work and others don´t
It sounds as if the channel that the phone and base has selected during that session is bad, or being used by another system in the area. When that happens, try selecting another channel. You should be able to do this by depressing a button on the handset. Normally labeled "Channel". Please post further questions or comments. Please rate this solution through fix-it. Thank you
Jun 28, 2007 | Motorola Mobility MA580 (612572111116)...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
