Whirlpool -ghw9100l wont start cycle
Power on. Push green CONTROL ON and green START but no response. Door is closed but no clicking like usually. Might have damaged something by trying to stuff a big comforter in there. All lights flashing okay. Just will not start the cycle. No error messages.
    Problem Solver:
  • 10 Answers
Defitive lid switch
Posted on Oct 08, 2008
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
My Whirlpool DU1055XTSQ has stopped working. The
Check that the door switch is operating properly, open and close the door a few times, push in on the door with a good amount of force while trying to start the machine, the door switch will not let control power to the panel if it is not getting triggered, to let the processor know that the door is closed and it can start the cycle.
Good Luck !
Feb 11, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
When I push and hold start nothing happens
can also be an issue with t door lock/latch assy, if it doeesnt recognize the door closed it wont start
Feb 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
My washing machine works most of the time but sometimes i need to push the door really hard a few times to get the cycle to start. Today it broke down half way through cycle, got it going again then the...
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
Sep 21, 2008 | Whirlpool Washing Machines
Washer will not restart.
unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
Sep 30, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
