Question about GE JTP85 Electric Double Oven
ERC3DD replacement Replaced Robertshaw control panel with a Sanyo ERC3DD for my GE convection oven. Control panel lights up, but oven doesn't become warm. I can hear the relay clicking.... instructions the new panel came with were for standard oven.
Powerman
  • 68 Answers
SOURCE: Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Posted on Oct 02, 2007
jumptrout51
  • 3361 Answers
SOURCE: GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Posted on Feb 21, 2009
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
  • 101 Answers
SOURCE: HELP!!!! GE Model PCB975SP1SS I have a
i wuold call ge service their techs are trained on ge products only ,it is covered by warrenty
Posted on Sep 10, 2010
  • 1796 Answers
SOURCE: replaced the ERC. Ovens
Hi!!
To install the new ERC3DD transfer the wires one at a time. All terminals on the relays are labeled as follows: COM (common), NO (normally open) and NC (normally closed).
  1. VIOLET wire to BROIL1 and BROIL 2 RELAY ON THE "NO" TERMINAL
  2. YELLOW wire to the BAKE 1 and BAKE2 RELAY ON THE "NO" TERMINAL
  3. ORANGE wire to the CONV1 AND CONV2 RELAY ON THE "NO" TERMINAL
  4. L1 wire to the BROIL 1 "COM" TERMINAL
  5. L2 wire to the BROIL 2 "COM" TERMINAL
  6. CONNECT the flat connectors. The terminals are the same.
  7. GREEN wire is NOT going to be used
Try it like this and get back to me.
Posted on Nov 20, 2010
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
Nov 29, 2015 | GE Profile PT916SRSS 30" Single Electric...
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Oct 02, 2007 | GE JTP85 Electric Double Oven
F4
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
GE JTP85 Electric Double Oven Logo
154 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
