RCA RCU403 Remote Control Logo
Posted on Jan 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to program a rca remote to a rca tv and i need the code
andy williard
Level 2:
  • Expert 226 Answers
  • Posted on Nov 30, 2012
andy williard
Expert
Level 2:
Answers
226
Questions
0
Helped
122942
Points
359
HI, if you are trying to program the RCU403. Go to following link to download the full manual:
RCA Universal Codes Manual
If you have some other RCA remote then you will need to find the manual for it. you can go to above link and click on RCA and browse through all the pictures of remotes, until you find the one that looks like yours. click on it and view details. They should have operating manual with codes for most RCA Universals.
5 Related Answers
Anonymous
  • Posted on Apr 14, 2009
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Anonymous
  • Posted on Oct 22, 2008
SOURCE: program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
freetek
Steve Allison
  • 5569 Answers
  • Posted on May 17, 2009
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Anonymous
  • Posted on Aug 13, 2009
SOURCE: philips universal remote #cl035a need rca tv, dir tv sat codes
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
I hope that this link helps you!!!.. Your Welcome.. I had the same issue.. tried this and hey! it worked.
Anonymous
  • Posted on Jan 08, 2010
SOURCE: need remote code for model L32HD41 RCA TV.
i purchased the GE 5 (Model 24950) remote, and i still couldnt get it to work. r u sure u have a RCA L32HD41 LCD TV?
Model LED32B30RQ need 4 digit code to program universal remote. RCA TV
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following:
11447 11758 11442
To program the universal remote to work with the RCA LED32B30RQ TV:
  1. Turn on the TV
  2. Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
  3. Press the "TV" button on the remote.
  4. Enter the 4-digit code for your TV using the number buttons on the remote.
  5. Press the "Power" button on the remote. The TV should turn off.
  6. Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance.
Note: The method to program the universal remote may vary depending on the remote brand and model
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
1helpful
2answers
Im trying to program the rca remote to my tv
Try any of the Sansui TV codes.
Sansui might be buying in some other brand of TV and rebadging it. Try the code auto search feature from the remote.
RCA code finder and support is here: http://www.rcaaudiovideo.com/remote-code-finder/ Download your user manual and have a read of the instructions.
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
2helpful
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
3helpful
2answers
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
1helpful
2answers
Need TV Code
trying to program my sharp tv and lost the manual to program my tv need the steps to program it help me
5answers
Finding codes
how program my control sanyo for tv curtis mathes
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
