I HAVE A RCA DLP TV AND THE LAMP KEEPS BREAKING EVERYYEAR
  • ladywinn
    ladywinn May 11, 2010
    What is your model and chassis number/ yr.I need this in order to be able to help.
  • 5,138 Answers
These sets only play between 5,000 up to 8,000 hrs if you play it day and night then you are using up lamp hours. You can not play these sets like projection TVs .
Posted on Oct 30, 2008
  • 41 Answers
Make sure the tv is at least a foot away from the wall so it can circulate air and keep the bulb cool. Try to avoid turning it on and off multiply times in a short period of time.
Posted on Oct 08, 2008
Burned out lamp RCA DLP TV Mod # HD50LPW165YX4 lamp type B
you can get the replacement lamp cartridge from the following link which also has installation instructions. Your model uses the 265866 lamp assembly.
http://www.tvrepairworld.com/rca_dlp_lamps
Aug 04, 2012 | RCA Televison & Video
I heard a "pop".
HD50LPW62 is Not projection,Projection TVs have 3 Tubes R/G/B.
Your TV is DLP which has Lamp and Color wheel, Ballast board, Lamp Fan.
You need to Check the Lamp,You will need to remove the back in order to see the Lamp.
Lamps are easy to replace.
Mats Electronics has Lamps 1-800-628-1118
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen keeps going out on my tv
If your TV is DLP projection there is the possibility that you have a bad bulb or lamp engine...]
If your TV is last a years now that is the problem because DLP bulb or lamp engine have a life span like your daylight lamp or fluorescent lamp in your house..
Jul 17, 2011 | Sony KP-53HS10 TV
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
