Question about Bloomfield 8571 Coffee Maker
Bloomfield 8571 Coffee Maker Problem
Water overheats(steam( and line cord get hot. Replace temp switch.
Any ideas?
Thanks,
John
    Problem Solver:
  • 11 Answers
Are yu cleaning it regularly? Scale build up in the tank will cause the heater to become less effective and the thermostat to read the water temperature incorrectly
Posted on Dec 01, 2009
  • sjbeach2001 May 20, 2013
    also the temperature is adjustable by a small screw on the controll unit which is located inside the tube that sticks out from it. remove the vent and place a thermometer in the tank through the hole, turn the screw counter clockwise until the heater shuts off at about 207 f at sea level. At higher elevations water boils at a lower temperaure so this value would have to be lowered to compensate. There is a chart for this in the manual which can be obtained through a web search. I won't post one here as they move from time to time as companies change their sites.
Why is my bloomfield leaking?
Depending on where it is leaking there are several places. I will illustrate in this drawing. The biggest problem on "non-water line models is the silicone elbows. Check them first. Unplug the brewer and remove the top burners and cover. Then get a pitcher of water and plenty of towels then start slowly pouring in the water and see if is starts filling up the top of the tank lid with water. if it does. remove the pour in tank, then remove the rubber/silicone elbows and if they come out easily, they are bad. Replace them. If you are going to replace them also replace the small 1/4 inch line that goes to the fill basin from the tank. It is about 8" long. Good luck.
Jul 15, 2014 | Bloomfield 8571 Coffee Maker
How do I drain a bloomfield 8571?
I would remove the big fat rubber elbow from the tank going to the fill basin...and turn the brewer upside down in my sink. This is how I drained about ten thousand of them (not joking about the ten thousand). But it depends on what you are doing. Did you want to delime it? Did you pour coffee in it by mistake instead of water?....What ever the reason be sure you let it dry out good. Coffee machines are use to flooding, spraying internally, leaking and they are built to shut down breakers. If you are pulling the tank or just removing the top, you may want to leave the water in to see how much water vs lime and sediment fill the tank. Depends on where you live. Enjoy.
May 20, 2014 | Bloomfield 8571 Coffee Maker
Our Bloomfield 8571 three pot burner is not working properly. It seems to be tripping the circuit and water is pouring over from the top and running down underneath the machine.
Without seeing the actual unit I would say it sounds like a hose is disconnected or defective. After disconecting the electricity the top can be opened by removing the two screws in the back of the top plate.
Jul 09, 2012 | Bloomfield 8571 Coffee Maker
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Instructions for bloomfield 8752 same as 8571?
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
Oct 23, 2008 | Bloomfield 8571 Coffee Maker
Bloomfield Koffee King coffee maker
TRY REPLACING THE SEALS IT WORKED FOR ME
May 22, 2007 | Bloomfield 8571 Coffee Maker
Bloomfield 8571 Coffee Maker Logo
166 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
Kelley Hopper
frankecoffee
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
