Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge refer leaking
This refer is leaking from the clear hose that runs up from a valve that is the bottom and is blue which is next to red valve which has a black hose attached to it. No change in function except that water is all over the floor I've had to turn off the water. No moisture in the drain pan
  • 120 Answers
If your refrigerator is a GE the water valve might be on the side onf the compressor the heat of the compressor has made the water line brittle and it broke if you need service call 562-688-3627
Posted on Oct 12, 2008
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Hi, how to you add more freon to 9,000 btu fugitronic portable a/c? Thanks
From the condensing unit you can see two valves. Connect the blue hose to the bigger pipe sometimes marked "S" to the suction manifold gauge with the blue dial.The discharge valve "D" is the smaller pipe and connect it to the red hose going to the red dial gauge. After connecting the hoses respectively, open the blue handle of the manifold to release air from the blue hose and close it. The same thing should be done to the red handle valve of the manifold. Connect the yellow hose to your freon cylinder and slightly open the cylinder valve while connecting it to the middle of the gauge manifold. Now, there is no air from all hoses and you can start charging freon when the unit start running. Check suction pressure and the Rated Load Ampere of the unit
Sep 03, 2011 | Fujitronic FA-9000 9,000 BTU Manual...
I have a GE profile Arctica with side by side doors (psc23ng). There is a valve at the bottom rear right (facing the refrigerator) with seperate red and blue connections for water. It appears to be a valve...
That sounds like the water valve that receives water from your house plumbing and sends it to your icemaker and to the water dispenser. In addition to the hose connections, there are likely some electrical connections on it.
The valve should be readily available at any of the appliance parts places that sell on the internet. It should be fairly easy to replace. Most of those are pretty accessible.
Oct 20, 2009 | GE Profile PFS22 33" Artica French Door...
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
Found a leak behind fridge,plastic hose is seperated
There is no connector . The plastic line pushes into the valve . If enough line is there , remove the short piece from the valve by pushing in on the white ring while pulling out on the broken line , and insert the main line into the valve with a little force . Check for leak by using water dispensor.
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water line leaking
unscrew the back panel and look if the plastic hose for the water (on the left side, goes to the blue/red valve block) is broken. If it is then you can buy a silicon tube or hose in a hardware store which fits on both ends (measure the diameter) you also need to buy two metal rings with a screw (don't know the name of these) which you can put over the connection to tighten it. The old hose has become very brittle in my case and this solved the issue
Feb 09, 2009 | GE GSS25LGM Side by Side Refrigerator
Leaky Water Valve Inlet
The part number for the valve for a pss26msrss is:
WR57X10032 it is around $45.00-$50.00. There are several look ups available but you need a complete model number that you will find on the refrigerator usually inside upper fresh food section. you can order at repairclinic.com, sears .com ... or you can google appliance parts and see what you come up with. You might also try a local appliance store. Good Luck.
Jan 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
78 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
