Question about GoVideo Go Video DVD/VCR Combo
Go Video Dual Deck VR2940
All of a sudden, the DVD tray will not close. Each time I click the remote or use the manual button to open/close the tray, the tray opens, closes and then opens again. When I finally DID get it to stay closed, the disc will not play, and the machine freezes.
I've tried turning off the machine. I've tried disconnecting it and reconnecting.
Still, the same dilemma.
Any help would be so greatly appreciated. Thanks in advance!
  • bettysgarage Oct 08, 2008
    Dear thenmoneypitt,
    I thank you SO very much for taking the time out to help a total stranger. Honestly, I thought it a longshot that anyone would reply, and am truly touched by your extending your knowledge, energy and time.
    I'm a little hesitant to open up the unit, as I'm not well versed with things of this nature, but I suppose there's a first for everything, so I will give it a go! If I don't find anything, I think I may just cash in my chips and look for another unit, as repairs cost almost as much as new machines do these days, so it might not be worth the investment.
    Again, my sincere thanks for all of your kindness and expertise. May it come back to you, when you need it, - tenfold.
    Sincerely,
    bettysgaragesale
    Scholar:
  • 157 Answers
Hello bettysgarage. A common malfunction in DVD players. The mechanics has a bad part or something is jamed in the rails, arms, lifts, ect. I suggest you unpluge the AC, remove the case screws(note witch screw went were), and look internaly for something in the mechanics, thread, paper, loose paper clip, ect. Carefully postion unit and reconnect the AC so you may see the action of the disk tray in motion. Please be careful you have AC power and can get SHOCKED if you touch the circuit or wire terminals. When no object is found you have a bad DVD that would require a local service technican to repair unless you are technically inclined to vinture futher. Good Luck.
Posted on Oct 08, 2008
  • Gene Pitts Oct 08, 2008
    Thank you for the reply. Good Luck.
    I sorry. I need to mention when you are inside with AC unpluged, reseat or wiggle the interconnecting cable or wireing in the unit to all the sockets or sensors. A loose connection may be a problem. Also check for obstruction in the laser switch sensors, clean with a Q-tip.
Tray in DVD player will not respond to front panel or remote for open/close menu says it is locked
Depending on the model, you could try pressing the "POWER" button on the remote and the STOP button on the deck at the same time.
Mar 01, 2011 | Video Game Consoles & Games
DVD player disc tray won't open
If unit has a belt drive to open and close the tray see if it has stretched or fallen off the pulley.
Aug 22, 2017 | Sony SLV-D271P DVD Player/VCR
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Does not respond to remote control
After power on the dvd, open the tray and put any video dvd in and close it, wait for about a minute, then press Setup or any button on remote control, if it work then need to replace with the new battery CR2025.
Jan 27, 2008 | Cyberhome DVR 1600 DVD Recorder
GoVideo Go Video DVD/VCR Combo Logo
85 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
