Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Ty-la1000 has been replaced, but won't light? could it be ballest board.
I have replaced the lamp on my PT-50LC13. When I try to turn on tv I get a steady flashing green light, then a red light and the lamp will not light unless I turn the tv on and off numerous times. Could this be the ballest board and if so can I replace the entire board, and were would you get a preassemled board. Inorder to simplify the job. I believe the board number is LSUC0022
  • afflatus May 11, 2010
    Is either the TEMP or LED light flashing? If so, mention which one and how often. The whole Ballast costs over $300. The part number you mentioned is simply an upgrade kit, a lot cheaper, but you will need to solder.
For the low price of $9.99 per month I will be glad to share the solution.
Posted on Oct 08, 2008
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
WERE exactly is the Lamp in my T.V ?
You must remove the plastic cover from the front and just left of center there is a panel covering the lamp with a single screw. Under that the lamp is also held in with a single screw. Pull on the handle firmly to remove lamp. Replace with TY-LA1000 bulb.
Jul 05, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I get no picture and the green light flashes then turns red.
LAMP TY-LA1500 orTY-LA1000 Call Fox they have them for 139.00 1-800-227-5369
Dec 14, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv won't turn on
I did a 2nd replacement with an original Panasonic TY-LA1000 Lamp, now my TV works just llike new.
Dec 17, 2008 | Panasonic PT-43LC14 43" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 Television Lamp Replacement
not really, just be careful about getting finger prints on the lamp as the oils from your fingers will shorten the lifespan of the lamp.
Mar 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
