Question about Lexmark Pro X125 All-In-One InkJet Printer
Used Lexmark X125 Printer
I recently bought a used X125. The drivers install fine, but nothing will print. The paper feeds correctly, the ink levels show ok, but nothing shows on the paper. What am I missing?
Thanks!
    Genius:
  • 1,913 Answers
Change your printer cable athen probelm remains uninstall driver install again.
Posted on Oct 07, 2008
I have a lexmark 125X printer. I started to print a job. the printer printed the first page. Then starting the second page it made a strange noise like "GEEK) and stopped printing. The printer...
maybe need to clean the printer and then restart your computer. Unistall the driver and then reinstall it back to resolve the problem.
melnavz
May 02, 2008 | Office Equipment & Supplies
I used to have the instructions on my desk top, but I accidently trashed them. If I install the ink in the printer without going through the computer and checking the ink levels, the ink "runs...
Please visit the Lexmark website to download and install the Lexmark X125 Printer Driver on your computer. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Aug 28, 2011 | Lexmark X125 All-In-One InkJet Printer
My Lexmark x125 all in one only prints blank pages
configure the proper port for the printer if you using usb cable for printer select the usb port in the properties of the printer ......
check the port you configure to printer
Oct 06, 2009 | Office Equipment & Supplies
Printer preferences won't open
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark X125 Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
To install:
You may copy and paste the web address below to access the Lexmark X125 XP driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:346:0:0&emeaframe=&fileID=533
Please use the following steps to download the Lexmark X125 XP driver to your desktop:
1. Select "Window XP" in the drop down list and click on "Download Now."
2. On the "File Download" screen, choose "Save."
3. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
4. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
5. Once the files have completed downloading, double click on the icon with your file name.
6. On the "Win Zip Self-Extractor" screen click "OK."
7. To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Apr 11, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark X125 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Lexmark X125 All-In-One InkJet Printer
Ink levels/streaky printing
remove the carts & using a wet paper towel, clean the nozzles on the carts to see if your getting any traces of ink. U can also go to the solution center & under maintainence u will fine an option Clean to fix horizontal. try this twice that should also clear any blocks then try this
  • Printer power OFF
  • Hold down the PAPER FEED button while powering the printer ON
  • Release button after powering printer ON
  • Test is continuous, so turn off when printing is complete
If the cart has any ink it will print 3 color lines & a blk line
May 12, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
It prints ok, but paper is blank (no ink at all)
1. Remove the protective tape from the cartridges:
1. With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
2. Remove the cartridge(s) from the printer.
3. Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
2. Clean the cartridge nozzles:
1. Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
2. Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
3. Clean ("wick") the cartridges:
1. Remove your cartridges following the instructions in your User's Guide.
2. Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
5. Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
6. Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
7. Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
8. Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
9. Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
10. If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
4. Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Oct 24, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark Pro X125 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
