Sounds familiar to me. Check for a loose screw on all the connections to the neutral bus bar. As the bar gets hot the holes actually enlarge slightly and increase the resistance. It does not take much resistance at 15 amps or more to get real hot.
Thanks to all of you who answered my question about the neutral bus which got hot -- including those who got into a debate about whether holes drilled in metal expand when heated or not. :-) Most of you seem to agree that the high heat was due to resistance caused by loose or corroded wires.
If anyone is interested in seeing a photo of the bus and wires, I have temporarily posted one at #
BTW, only two of your replies reached my ISP's News server. I did not find the rest of the 23 replies until I did a Dejanews search.
Thanks again.
Paul
Sent via Deja.com # Before you buy.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Scary Electrical Problem:
Solution #2
posted on May 25, 2006
Powe33 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Thanks again.
Paul
Solution #4
Mini Me - usenet poster
Re. all comments about bearings; the bearing is built around the "hole" the hole is NOT a hole in the sense of the original post ie. drilled and tapped. But please let's not go back to square one with this thread.
Digger, AKA Grumps (old and crusty) All errors; spilling, grimatical, ore tieping intenshunal.
Solution #7
maartenw - usenet poster
Sorry George, but this is one of the most common questions in basic engineering "Properties of Materials". The thermal expansion differential of the surface of a hole is found by analyzing the surface of the plug that came out of the hole.
Solution #8
Gary10 - usenet poster
Not true; the holes get larger because the circumference gets longer. Obvious with a wire ring or donut, but harder to visualize with a plate and a drilled hole, however, for the hole to get smaller the inner surface molecules or grain or whatever would have to compress...
If I have a bolt stuck in something, and I heat the something, will the bolt be stuck tighter? Or will it come free?
Solution #9
Horner - usenet poster
Hmm, well, perhaps the guy who has to heat an interference-fit bearing to get it to slide down on a shaft? Or the guy who heats a crankcase bearing boss so that the interference-fit bearing will drop down in the hole. Yeah, that's the ticket.
John
-- John De Armond johngdSPAM@bellsouth.net # Neon John's Custom Neon Cleveland, TN "Bendin' Glass 'n Passin' Gas"
Solution #10
M0nica L - usenet poster
I believe that would depend on the coefficient factor and whether any external magnetic flux was present, also the ambient temperature of the evnvironent altitude and crresponding atmospheric pressure. In other words WHO gives a rat's __?
Solution #11
Bomber - usenet poster
... Some bearings are assembled on machine shafts (such as used in lathes) merely by using a bearing heater to expand them. They are then placed on the shaft and allowed to cool. Cincinnati Milling and Grinding once made a lathe chuck of dissimilar metals where the inner diameter of the outer ring was actually smaller than the outer diameter of the part it was to assembled on. This was accomplished by heating the outer ring, while chilling the inner piece until they assembled, then letting all return to ambient temp. The outer ring contracted, the inner part expanded and the metals actually fused together.
Solution #12
jessie25 - usenet poster
I do, when George makes an a**hole observation like this one. Any apprentice knows how to shrink fit a bearing on a shaft. You heat the bearing, apply dry ice to the shaft, slip the bearing on the shaft, let things cool and heat up and voila, you got an interference fit. Hugh
Solution #16
Lizzy - usenet poster
Have not had this happen but my neighbour had a 27' Class C and every time he plugged it in the breaker would kick out for the circuit it was plugged in to. I started to check and found out the manufacturer had run the "shore power" wire from the main panel and had not tightened the clamps where it enters the box, then had secured it with "nyloclips" but only after the wire was pulled so tight the outside insulation on the cable was out past the clamp and the insulation on the individual wires got cut one the sharp edges of the knockout in the box...
Mo
Solution #17
Melissa - usenet poster
It is a good idea to check and tighten all electrical connections soon after purchase of a new MH. AND do this each few years after. The conductors "cold flow" like a wax candle in the sun much slower of course.
When loose resistance increases -- thus your smoke.
If the insulator in the panel is carbonized scrape off the carbon -- it is a conductor and can smoke again. Cut back the affected wires and splice in new, clean the screw, and the terminal, lubricate with silicone and reassemble tightly. Check in a month and then at one year.
He is not well bred that cannot bear ill breeding in others. Franklin, 1734
Solution #18
Perkins - usenet poster
On Fri, 21 Jul 2000 05:52:31 GMT, in message
I've seen it happen before, though it is reasonably rare (I've seen it happen in buildings, as well). Most likely it was a loose or slightly corroded neutral connection- once it started to heat, it went downhill from there.
The good news is that -most likely- if you hadn't been there, the connection would have gotten worse and worse until the power just went off. The insulation on the wire is (I think) self extinguishing, and the box itself would contain any threat of fire. This is one of the points about a UL listed device- they test not whether a device works well, but whether when it fails, it does so in a relatively benign way.
When you fix it- be sure to go back to good wire, and replace the neutral buss.
-- Chris Bryant Bryant RV Services- DeLand, Florida mailto: On RVing- TV about RVs, by RVers #
Solution #19
pawa - usenet poster
It is more than likely that one of the wires is loose and was arcing. Tighten all connections until you find the one which is loose, and then check the rest just to be sure.
-- Lon VanOstran Williamston, MI FMCA, Good Sam Life, SKP, NRA Patron
Solution #20
Rogers - usenet poster
You had a loose / bad connection which caused heating. Once this starts it's all down hill after that. I have actually had a fuse block at a household AC box disintegrate it got so hot. Multi conductor aluminum cables that are frequently used in high amperage circuits can be especially troublesome, even more so if used in fixtures not designed for aluminum. It's a good idea to check all electrical box connections once every few years as routine maintenance.
Al
Solution #21
kcw573 - usenet poster
Yesterday evening I was sitting at the dinette table in my motorhome addressing an envelope that I was about to mail. The motorhome was plugged into a properly wired and tested 30 amp receptacle. I was running the air conditioner, and the refrigerator was running on 120 v. AC. No other 120 v. appliances were in use. All of a sudden, I thought that I smelled something burning. It smelled like an electrical fire. I looked down at the Magnetek converter/charger/distribution panel under my seat. I felt the circuit breaker panel, and it was hot! While I was looking at it I saw a little wisp of smoke rising. I immediately turned off the air conditioning unit and went outside and cut off all electricity going to the motor home.
Today, I removed the panel that surrounds the six 120 v. circuit breakers. Some of the insulation of all six white wires which were connected to the negative or common bus was melted and black. Evidently, the whole common bus had become extremely hot. I hate to think of what might have happened if I had not smelled the melting insulation on those wires. (The circuit breakers did not open, either.)
Has anyone had this happen to them before? Do any of you electricians have a theory as to what happened? This is the first time I had any problem with the 120 v. electrical system in my 1993 motorhome.
