Question about ASUS P4XP-X Motherboard
Audio connection hi! when i connect my headset to the lime slot (that is for line out) does not produce sounds but when i connect it to the pink it has.in this case how can i use my microphone if the pink slot is for the line out?
  • 905 Answers
The setup for those are ; line in , line out & mic , with the motherboard utility's disk you should have a audio software configuration utility that allows you to change the configuration , like 5.1 output
Posted on Oct 08, 2008
I got a new motherboard, and the back only has a pink, green, and blue color for the jacks. However, these logitech speakers have a green, pink, orange, and black. i have the green and pink in and my...
PINK -- if you have a microphone, connect it here
GREEN -- if you have a headset, or you have external speakers, connect it here,
to get 2-channel stereo output ("left" and "right").
BLUE -- if you have an iPod (or iPod Touch), or audio-cassette player, and you want to feed the "audio-output" from those devices into a program that will record the sound on the "line-input" port on your computer, then you need to connect this port.
Since your new motherboard does not support 5.1 audio-output, you need to purchase a sound-card that has GREEN and PINK and ORANGE and BLACK sockets, so that you can get sound into the "middle" and "back-left" and "back-right" speakers.
Or, just connect the GREEN, to use your speakers in two-channel mode.
You'll also need to access the web-site for the manufacturer of the motherboard, to download the correct device-drivers for the audio-hardware embedded onto the new motherboard, in order to get _ANY_ output out of your sound-card.
Feb 17, 2011 | Logitech G51 5.1 Multimedia Surround Sound...
I cant hear nothings on my computer theirs no sound it says theirs is no speakers or headphones plugged in and wel they are plugged in (compaq presario SR5202HM) windows 7 ultimate 32 bit.
are you using a sound Card the presario SR5202HM has this sound setup
Sound/Audio Integrated Realtek ALC888 Audio
  • Audio CODEC: Realtek ALC888
  • High Definition 6 channel audio
make sure that this sound driver is up to date
here is the plugs
4 - Audio: Line In (light blue) 5 - Audio: Line Out (lime) 6 - Audio: Microphone (pink) make sure you have the headphones plugged into the Lime colored plug
if this doesn't work i have some more idea's let me know.
Jan 23, 2011 | Compaq Audio card Sound Card
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Hi, how can I connect my headset to my laptop ?
Since for the sound output connect to the lime green port on the laptop which is for audio out
Apr 12, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
I've just bought a desktop from Cube (the Polaris ST12) which comes with Creative Inspire T6100 5.1 speaker system. The connection instructions which come with the speakers show 3 cables from the subwoofer...
The blue is for a audio in and pink is the mic. Green is the audio out.
You will need to buy a new video card that has all 4-5 colors (green,,black,orange,blue,pink,white)
That way you can plug in all your connections and it'll work correctly.
Oct 23, 2008 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
My headset isnt working all anymore. it shows my mic is connected but no sound is produced
Check if your receiver is muted, if not it seems that your headset has the problem. Maybe the supply is cut inside the connection in the headset. Check it out.
Jul 09, 2008 | Audio Players & Recorders
Headset fixing
hi
there are 2 pins in your head set. one is green and the other is pink.
The green is connect to audio our(SPeaker) and the pink is connect to mic
Feb 23, 2008 | HP (198710-001) Computer Speakers
ASUS P4XP-X Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
