Question about Magic Chef Kitchen Ranges
I need to convert a magic chef stove from lp to natural gas. Do I need a kit or is there an adjustment? Model: 34MN-3TKVW code: EV Serial #: 05C224386177
    Genius:
  • 1,122 Answers
Should be brass fitting on the back of the stove,let me know-mike
Posted on Oct 07, 2008
Is there a conversion kit for magic chef CPR1100ADW
Yes, there is an LP conversion kit for the CPR1100ADW. Sears Parts Direct lists it here: http://www.searspartsdirect.com/model-number/cpr1100adw/1429/0124002.html . Select the Gas Control drawing. The direct link to the LP orifice kit, part number 74009923, is http://www.searspartsdirect.com/part-number/74009923/0022/464.html?modelNumber=CPR1100ADW&categoryName=Free%20Standing,%20Gas&brandName=MAGIC%20CHEF . Note: the Magic Chef range uses the same parts as a Whirlpool or Maytag range.
The gas regulator also has to be adjusted. Most ranges with converter kits available just require the regulator to be removed and turned 180 degrees before replacing it. It's recommended that a LP service person do the work. The air flow may need to be adjusted and any mistakes could be dangerous.
I hope this helps.
May 06, 2017 | Magic Chef Kitchen Ranges
Convert from natural gas to lp
You can purchase an LP kit and install it on your burner
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
Convert from gas to lp
This is going to result in you needing a different metering orifice on the gas valve. There are LPG kits to install this, but I highly recommend a professional to eat the liability on this one because LPG is heavier than Natural gas and if it's installed improperly, a leak will cause the gas to settle on the ground creating an explosion hazard.
I have a Magic Chef Range model number 31fn-7 and I need to find out how to change it from Natural gas to LP
You should be able to go to Lowe's or Home Depot and ask them if they have a LP conversion kit. They should be pretty much universal...however, you need the installation booklet and/or the owner's manual. There should be a diagram in the book that tells you what size orafice goes where...If you really want to insure that you have the correct orafices for your model specific unit, contact the Mfr. and they should be able to give you all of the correct info.
Jan 31, 2013 | Magic Chef Kitchen Ranges
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Dec 15, 2008 | Kitchen Ranges
We are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic...
Hello dradon,
Welcome,
You said,we are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic Chef 3110PRW
I am glad you asked us before attempting to do this change!!!!
This is something that should be done by a qualified gas technician due to safety concerns.
Here is a number that you can call to see if there is a kit available for your model.
Magic Chef
Customer Experience Center US 1-800-688-9900 Canada 1-800-688-2002 or Consumer Parts Dept 877-232-6771
I'm glad I caught you before you started.
I know of some tragedies from this!
Huuum
Oct 16, 2008 | Magic Chef Kitchen Ranges
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
216 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
