Question about Kenmore 73952 Gas Dryer
Thermal fuse Where is it located? on the kenmore top vent gas dryer?
  • raindrop132 Nov 11, 2008
    hi, my kenmore gas dryer is having problems with drying clothes taking very long time and i checked the ignitor it does the job but gas shuts off in few minutes i did clean the duct still having problems if you can suggest the solution please.
    khan.
    thanks
  • 943 Answers
HI sorry the thermal fuse is located on the air duct, on the left a small plastec piece with 2 blue wires to it , the hi- limit is located on, the heater box.
Posted on Oct 11, 2008
    Genius:
  • 1,122 Answers
The thermal fuse is located on the heater box,the main fuse is located on the blower box,let me know-mike
Posted on Oct 07, 2008
3 Suggested Answers
wrightly
  • 140 Answers
SOURCE: My Kenmore series 90 gas dryer (lint screen on the
hello.
You likely will need to replace the 2 coil valve solenoids at the top of the burner. These safety coils may gradually fail over weeks or even months giving partial heating and longer dry times. As the coils are going bad, they will work for just a brief amount of time, then after a half hour or so of cycling on and off to maintain the drum's temperature, they'll break down and cease to open the valve.
http://www.repairclinic.com/PartDetail/Gas-Valve-Solenoid-Set/279834/3479
This link here will show you what they look like and how to replace them, along with some more helpful tips.
I really hope that you find this helpful. Helping others is what I love to do. If you need any further assistance, I'll be happy to help you if I can.
Thanks,
Mike
Posted on Jul 21, 2011
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
Posted on Feb 04, 2009
I should like to have a Dutch or English user manual
Obstructed Vent
Your Kenmore dryer must be able to freely circulate air in the dryer in order for it to continuously supply hot air. If air flow is limited from a buildup of lint in the vent and lint tray, the high limit switch temporarily shuts off heat to the dryer. Empty the lint tray on the top of your dryer. Detach the exhaust vent -- the silver tube in the back of your dryer -- and thoroughly clean it out with a lint brush and reattach. Consult your Kenmore dryer manual for instructions on how to inspect and clean your vent hose. Once these components have been freed of lint, the dryer should dry clothes again.
Broken Blower Wheel or Belt
If you have completed a full inspection of your dryer vent system and found no obstructions, your dryer might have a defective blower wheel or belt. A failure of one or both of these components can restrict air flow in your dryer and take your dryer longer to dry clothes. According to Point and Click Appliance Repair, a noise coming from the dryer as the drum spins is usually an indication that the blower wheel is failing and needs to be replaced. Review your Kenmore dryer manual for instructions on how to locate these components on your dryer.
Faulty Thermostat
A broken thermostat can cause your dryer to produce too high or too low heat. Monitor the dryer exhaust temperature with a hand-held thermometer. The temperature should be below 150 degrees Fahrenheit. If the temperature reading is higher, then replace the thermostat. It's no longer able to regulate the temperature inside the dryer, and your dryer is in danger of overheating. If the temperature reading is room temperature and the dryer is running, the thermostat is broken and needs to be replaced.
Damaged Gas Valve Coils
Damaged gas valve coils permit your Kenmore gas dryer to ignite only once before coils must completely cool in order to reignite. This is a common issue among older dryers. If your dryer struggles to turn on or after it shuts off you must wait several minutes before it restarts, then the gas valve coil likely has worn. Confirm the location of the igniter from the manual. It's a cone-shaped tube that is located inside the dryer near the front panel close to the bottom. If the igniter radiates bright orange for 15 seconds without producing a flame, then the gas valve coils have probably failed.
Mar 10, 2011 | Zanussi Dryers
Our kenmore # 110-728220 turns but no heat. replaced ignitor still no heat
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 13, 2009 | Kenmore Dryers
Kenmore gas dryer 70932, 70942, 70952 won't heat. Dryer turns on and tumbles but won't heat.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Oct 04, 2009 | Kenmore Dryers
Not heating
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 10, 2009 | Kenmore 73952 Gas Dryer
My dryer runs but does not heat Kenmore 110.74722400
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 05, 2009 | Kenmore Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore dryer will not heat
If gas, check the following areas.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If electric, check the following.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 19, 2009 | Kenmore Dryers
My kenmore gas dryer is not heating.I have taken apart and cleaned the lint trap as well as run a shop vac through the vent.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 17, 2009 | Kenmore Dryers
Kenmore Gas Dryer runs no heat were do I Start first
Check the following to address your issue. check each section of the dryer thoroughly.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 15, 2009 | Kenmore 74602 Gas Dryer
Kenmore 73952 Gas Dryer Logo
507 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
