Question about Sharp AL 1631 Copier
Get and "L' message on the readout - it does not move when you turn it on
The scanner and lens makes a bad noise when you turn it on - it does not move.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Most likely the sensor that reads the scanner is at home position, is out of place.
It is probably hitting or rattling against the right side.
remove glass, (W/POWER OFF), move scanner away, and look on the sides of the machine there should be a U shaped sensor there, on the scanner there should be a L bracket that goes between the sensor
Posted on Oct 08, 2008
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Camera not moving during scanning. Looks like stuck.
I have many years experience repairing Canon scanners so here is my suggestion for you.
That is a common problem with that model of scanner. Make sure you have the lock released for the scanning lens first. If it is realeased you may have to remove the glass assembly so you can gain access to the scanner lens. They sometimes jump off their track in shipping. If you can move your scanner lens freely by hand then I am sure you have a bad motor. Before you do any of these things I have suggested make sure the power is disconnected at the wall to the scanner.
I hope this helps you out.
Mar 23, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
Scanner lockup
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.(You can apply little more pressure if it does not move easily)
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.(If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Oct 19, 2008 | HP PSC 2410 All-In-One InkJet Printer
Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
Officejet 7130
Good Luck
Aug 18, 2008 | HP Officejet 7130 All-In-One InkJet...
Canon copier PC720
A E2 code deals with the scanner. The optics of the copier. Has itbeen moved resently? Your lens may be off it's track. Turn the copier off and remove the copy board glass and the Black Box and try to move the lens and the scanning mirrors to see if they can move smoothly. If not you have found your cause of the noise and what needs to be repaired. It may not be worth getting fixed. That is older model, it's up to you..
Jul 25, 2008 | Office Equipment & Supplies
Scanner
If the unit is in warranty, get Epson out to it. If not check the simple things like making sure the head lock is not on. Look to see if the scanner head starts to move at all when you power up the unit. If the head does not move at all or makes an unusual noise, chances are the unit is complaining that the head is stuck or requires too much effort to move it. Other possibilities include a communication error between scanner and main board of the SPC or SPC and your computer - indicates broken connection or bad USB cable. POssibly a fault with the mainboard of the SPC itself. Error ?Cause *Remedy Scanner error ? Lamp has burnt out. * Replace the scanner lamp. ? Power is turned on without unlocking the scanner. * Unlock the CR. ? The scanner carriage is interfering with any other part. * Remove the obstacle. * Replace the scanner carriage unit.
Jun 22, 2007 | Epson RX620 All-In-One InkJet Photo...
Sharp AL 1631 Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
