Question about Canon Office Equipment & Supplies
Canon bjc 50 printer
There is no paralel port on my new laptop so to connect bjc 50 i must use usb port. once connected via usb-paralel adaptor, printer is recognised but any file sent to print hangs - no printing! OS is Vista, but same problem is with XP also, so looks like driver don't create the problem - problems seems to be with paralel connection via usb virtual port?!
    Problem Solver:
  • 18 Answers
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Posted on Aug 20, 2009
  • Canon Master
  • 4,338 Answers
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Posted on Oct 07, 2008
    Genius:
  • 1,913 Answers
No
install poreprdriver for your printer try to hcange cabel
http://www.printcountry.com/drivers/CANON_BJC_50_DRIVER_DOWNLOAD.htm
I want to purchase a laptop printer Canon bjc 80 will it connect to my vaio via the usb or whatever the 15 pin plug is on the left hand side
According to the specs this printer uses IEEE 1284 connection which is infrared. So you would have to have an infrared receiver/transceiver on your laptop or purchase and install one. In other words this printer does not connect directly to your USB port or your Paralell Port.
Mar 27, 2010 | Sony VAIO PCG-K35 Notebook
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
Feb 19, 2009 | Canon BJC 80 InkJet Printer
Canon bjc 80 printer- no driver- ibm thinkpad laptop- compatible?
You can download the software from Canon.
Here is the page to download the driver from:
BJC Support
Click on the "Drivers & Downloads" tab. Select your operating system from the dropdown menu. (Windows 98)
Click on the red link for the driver BJ_v397.exe.
When the download window opens, select "Save" and select a location you know how to access after the download. For an easy way, save it to your Desktop.
After the download, connect the printer, turn it on. Then run (doubleclick) the file you saved.
Feb 12, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 80 New Cable Required
You Can Get Them At Radio Shack, Circuit City Or Best Buy Maybe Even Wal-mart
Jan 07, 2009 | Canon BJC 80 InkJet Printer
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
550 people viewed this question
old marine
old marine
