I have a brother dcp110c printer, recently every time i try to use it it comes up stating that the scanner cover is open. checked the cover but it is closed what can i do?
    Genius:
  • 1,913 Answers
Off the power and open backside of printer then refix it.
then refix the cartidge then try
Posted on Oct 07, 2008
Brother HL-6050DN Printer gives "replace laser scanner unit" message on led.
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
May 21, 2010 | Brother HL 6050 Laser Printer
Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Apr 22, 2009 | Lexmark X7170 All-In-One InkJet Printer
I have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Oct 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brothers Printer
try to clean the printer by selecting clean and then test print the ink
Sep 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C printer error
you cant clean the waistinktank because when the felt dries up it wont take up any ink anymore! The rejected ink will flow into machine and cause serious demages!
Anyway you have forgotten to reset the eeprom code to tell the machine thta the ink absorberbox has been CHANGED!
Search here for error 46
Feb 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Printing blank page
I have the same problem, does anyone know what I can do. I have tried cleaning the head but it doesn't work.
Feb 07, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP110C Instalation Disc
download software + driver package from brother homepage of your country
Oct 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
Scanner or PC?
Neither is it a prob with the computer nor with the scanner.
Let me guess,
either is your usb connection cable longer than 2m or you have connected the usb printer/scanner cable to a usb hub.
Do use a cable no longer than a max of 3m and do connect the usb cable directly to the computer usb slot.
Oct 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
Startup problems with the Brother MFC-5840CD All-in-one
You have to open the scannerbox very carefully. There is a contact on the lefthandside placed where the motor and belt is located. Check the position of the motor an ohter parts, by carefully sliding the scanner bar by hand. You may need to click in some parts because they have got loosen. Reassemble scannerbox.
Aug 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
48 people viewed this question
jasbo
jasbo
