Question about OKI C5100n Laser Printer
K image drum
I have relpaced the black drum but the message order K image drum constantly runs across the screen. what does this mean?
  • OKI Master
  • 4,338 Answers
The K drum sensor is probably covered with toner residue.
First clean out excess toner spill and see if you can clean the sensor , which should be an opening on the right side wall directly across the K drum. Use a cottonswab with alcohol.
If the sensor is bad, you should have a tech look at it, The sensor board is held in with14 springs!
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 07, 2008
After Warming up....The error message is E000020-0460..what is the problem
Hello Rama,
I will answer your question however you will determine the solution.This error code means that when your device went through it's "self diagnostics"in an effort to provide you with the optimum image quality a failure occurred.The target for image quality for BLACK could not be reached.The black drum has reached and went beyond it's ability function.Replace the black drum.The part number is 0258B001AA.It is easy to replace and there are many sources on the web.The cost is around 175 $US. . The estimated life of the black drum is 78K.Keep in mind that virtually every image you generate has a black component.The E000020 means one of your 4 drums have failed.The 0460 says 2 things.The 04 means black drum.The 60 that follows means which component of the black drum(the developer)has failed.I am glad to help you and save you a service call.Please let FIXYA know I helped you, and have a blessed life. SPINAL
Jul 31, 2011 | Canon imageRUNNER C5180 Color Copier
My copier machine is printing out black lines.
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on emma.servis@gmail.com.
Hope that helped!
Jul 30, 2010 | Canon imageRUNNER 2270 Copier
Display is black and white unable to see behind
Sounds like the screen needs to be replaced.
Aug 05, 2009 | Computers & Internet
Black screen white dots
This is likely due to Hardware Failure. Your GPU (Graphics Processing Unit) has likely overheated to the extent of artifacting which is when the device begins to have trouble rendering objects and images and crashes constantly. The only viable solution is to send it in if you still have warranty, Otherwise, you'll have to either buy a new Xbox 360 or send it in for repairs from microsoft.
Hope this helps.
-Gadorach
Jul 13, 2009 | Microsoft Xbox 360 Console
OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Apr 18, 2009 | Office Equipment & Supplies
Signal on screen ''life warning''
AFTER CHANGING DRUM KEEP DOOR OPEN AND HOLD THE CANCEL BUTTON FOR 5 OR 10 SEC. IT WORKED FOR ME
Apr 13, 2009 | Dell (2333R) Motherboard
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Jun 30, 2008 | Canon imageRUNNER 2200
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
OKI C5100n Laser Printer Logo
944 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
