My rear projection tv stopped working the lamp has not blowen but the lamp is showing its open circuit with a multimeter. Should it be open circuit? the model of the lamp is 120w BP96-00271C
  • 185 Answers
Yes it is high resistance could be your balast... do you hear the arc in the spark gap on the ballast?
if not you may have no power to the ballast as in an open fuse or the ballast is defective or your bulb is defective ..they may not look blown.
Posted on Oct 08, 2008
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
My tv is showing the green light but the screen is still black. what should i do?
If your tv is RCA P52926 then it is rear projection tv that does not have a Lamp inside, this rear projection tv three picture tubes to make picture/ image on front screen.
I disagree with previous expert given info about Lamp in this tv.
Since tv is an old model so it might got problem in deflection circuit or power supply stop working properly that is why tv is not turning On to show you picture.
Local tv repair shop will help you to get it fix.
Aug 10, 2010 | RCA P52926 52" Rear Projection Television
Video went blank
It may be. I have replaced the lamp in my sony 3 times. Look for dlp lamps online and enter in your tv model. There are instructions online on how to change it yourself. They also show you in your manual. The power light should blink red indicating bulb failure. Read your manual. Hope that helps
Apr 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
When I power the TV on there is no picture, the lamp light is flashing, and there is a squeaking noise coming from there rear of the TV. It kind of sounds like a wheel turning and rubbing against...
The squeeking sound could be the high voltage trying to strike the lamp, it will try several times to strike the lamp then shutd down. Take the bulb out and see if it s blown. Even if it is not blowen it sounds like you have a bad bulb.
Sep 01, 2009 | Samsung HL-R4667W Rear Projection...
I HAVE A SONY 55 INCH TV THAT IS NOT WORKING.
Symptoms shows lamp is broken and TV requires new lamp.
Let me know exact model of TV to provide you lamp purchase info.
You can replace lamp easily as procedure is written in user manual.
Mar 28, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv bulb
You set a Multimeter to read impedance (ohms) then put the two sensors of the Multimeter on the lamp contacts, if it reads infinite impedance, then lamp has blown.
Dec 16, 2008 | Hitachi 60V500 60" Rear Projection...
The lcd screen on a dvd/tv combo has stopped showing the image although the rest (sound, power etc.)works fine
could need a power invertor for back lamp may need back lamp or signal circuit board or power supply circuit board replacement or repair$$
Sep 19, 2008 | Televison & Video
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
