Question about Whirlpool MH7155XM Microwave Oven
Whirlpool microwave mh7140xfq
I have purchased the diode for this model. I cannot locate the old diode to replace it. Diagrahms I find are not very clear. I have the front control pad off(hanging) and can see wires, cage blower wheel, etc. Do you have a real life picture pointing out the diode? Thanks.
steve
  • Whirlpool Master
  • 9,085 Answers
Curious, but did you know the diode was shorted without measuring it before you ordered the new one? I hope that's the problem.
In any case, there should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
It usually has a perspective view drawing showing the relative locations of the components (parts layout).
If you don't have your tech sheet, you can find it online here and look on pages 3 & 4.
The diode (rectifier) is connected to one terminal of the high voltage capacitor and the other end goes to the chassis for ground.
It is located behind the magnetron in the back of the unit. You'll probably have to take the oven down from the wall to get to it safely.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.
Please read & heed the safety info in the tech sheet.
Posted on Oct 08, 2008
Whirlpool MH7140XFQ Fuse to Breaker Problem
There is absolutely no way to guess at the problem. You need to troubleshoot the circuitry with a meter to find the failing component
Oct 06, 2009 | Whirlpool MH7155XM Microwave Oven
I have a whirlpool model MH7140XFQ and we got a guy to come and look at it and he said the Mag. tube and the circuit bars were broken. Which would be more expensive to change the broken things or just...
He is referring to the magnatron tube which is the heart of the microwave. Probably more expense than you would want to put in to it.I would recommend replacement unless it is a high end model. Hope this helps
Jul 24, 2009 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave not working
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Dec 19, 2008 | Whirlpool MH7155XM Microwave Oven
MagiCook 22C not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 14, 2008 | Whirlpool GH7155XHS Microwave Oven
Whirlpool mh7140xfq
Here are some links you can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
The average DMM doesn't have a high enough voltage to bias a high voltage diode, which is several diodes is series.
If the diode was not shorted, it was probably okay. They almost always short when they go bad.
I don't advise people on measuring a microwave's high voltage. The voltages can be instantly lethal.
The tech sheet should show you how to measure the resistance of the windings of the high voltage transformer. You know you're getting 120V on the primary.
The capacitor is probably okay because they usually short when they fail, and that would blow the fuse when you hit Start.
Look for corrosion or signs of melting on the FA terminal of the magnetron (and on the other temrinal if someone reversed the wires). Look fro a loose connection at the magnetron.
If these connections are fine, then you probably have a bad magnetron.
Probably the best prices on Whirlpool parts can be had here.
Oct 22, 2008 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH7140XFQ
It's most likely caulk. It can usually be sliced with a razor blade.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
Owner
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 09, 2008 | Microwave Ovens
Whirlpool MH7155XM Microwave Oven Logo
263 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
