Question about Garmin nuvi 350 GPS Receiver
I have a Garmin 350 that won't load maps and stays frozen what can I do to fix problem
I,ve tryed to reboot but it did not work unit turns on and will not progress thru it shows loading maps but stays there
  • 1 more comment
  • coesteves Oct 24, 2008
    I'm having the same problem, I just bought a Garmin Nüvi 350 and when I turned it on, it is showing "loading maps..." and do not go foward. Anyone knows what I'm supposed to do???
    Thanks
  • Anonymous Nov 30, 2008
    I have the exact same problem. Just keep saying "Loading Maps"
  • alia-haider May 11, 2010
    i have request that my Garman nuvi's map is not working please help me for the map loading. thanks
    Problem Solver:
  • 6 Answers
Have you tried a software upgrade. Talk to Garmin, they were pretty helpful when I talked to them.
Posted on Oct 17, 2008
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Starts up but will not load maps
I had this problem with my nuvi 1300. I'm not sure if the same procedure will work for yours, but this is what I did.
I tried holding the power button for 10-15 seconds, which rebooted the unit, but it kept getting stuck on "Loading Maps." and then shut off.
I then plugged it into the USB port of my PC, which started the unit up for data transfer purposes. I then unplugged it, and it restarted properly.
Apr 12, 2010 | GPS
Garmin Nuvi 255w won't turn on and remain on
pull the surround off the front of the front of the gps. there should be a button under the plastic or look on the back and there should be a reset button that you can stick a pinhead into. if that doesnt work then your gps doesnt work and you need to replace.
Jun 13, 2009 | Garmin Nuvi 255 GPS Receiver
Nuvi 205W keeps rebooting.
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
Jun 02, 2009 | Garmin nuvi 205W GPS Receiver
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 12, 2008 | Garmin Nuvi 660 GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
GArmin 2620
In February I posted that I will replace the cornice drive on my 2620 because I had this problem 019d1f6.jpg Well I did that, but could not fix the problem. Garmin is asking $275 to replace my unit, I did not wanted to pay them that much. So I bought a 2610 at eBay for a $100 and don't have to worry about hard drives any longer.
To get this screen on a GPS push "menu+find" and then turn on unit. It will show this diagnostic screen.
Jul 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
147 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
