Question about Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC)
Wireless network adapter(code 10) and pci modem (code 28)
Having trouble connecting to my home wireless network
  • chady_rahme Mar 06, 2009
    My wireless card cannot detect any wireless network
  • 1,913 Answers
Install proper driver then set ip adress .
enable wireless adapter.
Posted on Oct 07, 2008
Won't Connect to the Internet
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake
Feb 10, 2013 | Gateway LX6810-01 PC Desktop
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
Example of a wireless USB device,
Example of an Ethernet adapter card,
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
This is for a Dell Optiplex GX620 Mini-Tower computer,
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
What kind of PCI modem does the machine have?
Your computer has (3) network adapters.
  1. An integrated 10/100 Network Adapter
  2. An Intergrated IEEE 802.11g Network Adapter (Wireless)
  3. An ITU V.92 modem
Oct 21, 2009 | Gateway MX7515 Notebook
Problems with wireless connection - gateway notebook
Might be several things, but perhaps start with checking for any driver updates that might be available.
Feb 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless connection
My other half has this problem on his Acer laptop with Broadcom 802.11 wireless. This is how I have finally solved it.
1) Open Internet explorer
2) Type in your ISP address (tiscali is so will be something similar to this for other ISP's)
3) This opened the ISP configuration screens and I opened 'SetUp'
4) I had to choose 'PPPoA'
5) I had to then enter the main username and password on the account
6) Set the connection to 'Always On'
7) Save Settings - this rebooted the internet connection (did not reboot the whole laptop) I closed the wired connection and disconnected the cable at this point.
8) Right click in your Wireless Icon on lower taskbar
9) If no wireless connection showing click to search
10) I then got a screen asking for the network key for the modem (mine is on the bottom of the modem but I keep it written down then I dont have to fiddle with the modem
Finally - Connect !
Hope this helps :-) By the way I got this info from ISP website by entering their 'Help' section, typing in 'Wireless' and clicking on the option that came up for my particular modem type.
Good Luck !
Jun 29, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
try to unplug it all modem roughter then modem roughter computer on see if its working do repair also thx nick
Feb 05, 2008 | Computers & Internet
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC) Logo
397 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
