Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42 in L42HDTV10A no power no lights no nothing
Had the Vizio TV on when weather caused a sudden lose of power. TV now does not show any power indications, lights etc....just dead. I checked the voltage on both sides of the fuse on the power supply board and measures 110v. Fused tested okay. I attempted to measure the output voltage of 5 and 12 volts for connectors to other main boards and it didn't register any voltage. Not sure I did this correctly. I set meter on 50v DC and grounded one lead and touched red lead on the connector pins. Nothing. I've read the power supply board and main board are common replacements. Is there an easy test to determine problem on model L42HDTV10A? I'm thinking about replacing the power supply board as this is cheaper than main board.
  • Vizio Master
  • 749 Answers
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
Posted on Apr 25, 2013
  • 41 Answers
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
Vizio plasma tv
what connection are uusont tivo ? have u tryed other sourses
Jan 28, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Have Vizio TV, powers on, but blank screen, no backlight
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
Dec 05, 2013 | Televison & Video
My vizio L42HDTV10A mfg date:november 2006 turns itself off about 5 secs after I turn it on. Is it fryed or can this be fixed?
it can be fixed the problem is in the power supply..but since the tv is old my advise is to buy a new one as it will cost you to get it repaired.if not then get a repairman to do the job.good luck.
Sep 23, 2011 | Vizio Televison & Video
Vizio p42hdtv10a
Bad interface circuit or power supply. Needs servicing..
Jun 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
May 04, 2009 | Vizio L32 32 in. LCD HDTV
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
989 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
