Question about HEC Group ACE 580UB 580-Watt Power Supply
HEC 580 WATT IN EGYPT
I ALREADY BUY THIS POWER AT YESTERDAY AND WHEN I CONNECT IT WITH MY MOTHER BOARD GIGABYTE P31 I SEE A LOT OF SMOKE OUT FROM THE POWER THEN I KNOW IN THIS MOMENT I LOST MY MOTHER BOARD EXACTLY THIS HAPPENED
    Genius:
  • 1,605 Answers
What is the porblem??
you lost the PS and the motherboard.
Posted on Oct 14, 2008
How to check processor working
Hello dear,
If your motherboard power lamp will be off/on automatically, it could be related to bad supply unplug all connection and plug it again proper if still you have same problem then you can try another OK power supply
Jun 08, 2012 | Gigabyte GA-M51GM-S2G Motherboard
I want to buy a hard disk for my PC. Model of mother board is GIGABYTE 8VM800M. How much size of HDD does it Support.
The specifications for this model Gigabyte moterboard is available from this WEB site.
http://www.gigabyte.com/products/product-page.aspx?pid=1931#ov
This motherboard supports IDE and SATA hard drives.
There is no size linitations on SATA hard drives and they are a lot faster than IDE hard drives.
I recommend to install a SATA hard drive with a capacity to suit your needs.
Jul 09, 2011 | Computers & Internet
I have changed the motherboard from Intel to Gigabyte(GA-G32M ES2L) since then the problem of my pc freezing while playing games started. My configuration is Processor:Pentium D...
1) Make sure that your Power Source is giving enough energy to the new Mother Board and make sure it's compatible.
2) Make sure that the new Mother Board is compatible with all of your current hardware, you can check this in the webpage from the Mother Board Company.
3) Check the voltage requirements for the Mother Board, check the BUS speed of the Mother Board and compatibility with the transfer speed of each of your current hardware.
4) It's never recommended yo change only a Mother Board since usually there's going to be problems with the rest of the hardware if it wasn't changed, if the problem persists, you'll have to buy new hardware that is compatible with your new Mother Board.
5) If you know how a BIOS works and how to configure one, you could also check the configuration in the BIOS, not sure it will work but it's worth a try if you know what you're doing.
May 27, 2011 | Computers & Internet
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
I need help choosing a Graphic card ...
Man, trast me, the GTS 250 is way better than the hd 4870 one. on each section of the measures of performance factor, 250 beats the 4870. PhysX is the hardware utility for making the real world effects like the gravity , air factors, sea waves more realictic easily .
Apr 18, 2009 | HEC Group ACE 580UB 580-Watt Power Supply
Orange connectors (3.3v) brown
thats probably dust and static dirt, if the power supply worked fine before then there should be no problem providing that the pin arrangement is the same, test it on you old mobo to check it!!!!
Nov 14, 2008 | HEC Group ACE 580UB 580-Watt Power Supply
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
HEC Group ACE 580UB 580-Watt Power Supply Logo
127 people viewed this question
Top HEC Group Computers & Internet Experts
David Payne
David Payne
Are you a HEC Group Computer and Internet Expert? Answer questions, earn points and help others
