Question about Harman Kardon AVR 130 Receiver
Low sound output
I hooked up my AVR 130 as the amp for a new polkaudio soundbar for a flat panel tv.  although i'm still uncertain what mode i should be using for best results it sounded great.  for a day.  now i have to turn the volume on the HK to eleven to get somewhat decent audio.  read the manual, installed correctly, checked the cable box settings as well as the television but nothing helped. i noticed the remote had some issues at the same time...turned on the hk instantly but then had to mess around with the new batteries and squeeze hard to get a response.  remote works ok now but sound..not so much.
SOURCE: HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Posted on Jan 03, 2009
  • 34 Answers
SOURCE: static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Posted on Jan 29, 2009
  • 103 Answers
SOURCE: The unit will play for 5 min and power off. (HK avr 70)
please check if you have enabled the sleep mode for 5min...if so disabled it from your settings
Posted on Oct 12, 2009
  • 382 Answers
SOURCE: HK avr-25 - everything seems to work except sound
Check the speaker 1/2 buttons that turn the speakers on and off, they have a habit of getting corroded. Click them in and out about 20 times each.
Play with the balance knob, run it side to side about 20 times. Turn the unit off and do the same with the volume knob.
Ensure mute is off.
Check that the tape monitor is off.
Check that you are on the correct input.
I cannot remember if the MK2 had pre-out to main-in bridges on the back, if it does make sure they are pluged in all the way.
Let me know if this helps,
Posted on Feb 03, 2010
Testimonial: "Some good things to try. I will later today. Thanks"
  • 4234 Answers
SOURCE: HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Posted on Apr 06, 2010
Medion Soundbar P64124 connected to tv, but no sound
How are you hooking it up?
Double check output on tv. I had one go bad on mine so I ran it through receiver (hdmi) then to soundbar
Oct 16, 2016 | Medion Televison & Video
I have a 42 Insignia TV and a Vizio 3821 sound bar. I also have Dish Network Hopper on this TV. I have tried all sorts of hook ups, but still no sound. Help
Soundbar & TV connection issues...Please Help!! - TV - Audio
Aug 5, 2013 - the tv does have an optical output according to the website, it may just look hidden because ... I am trying(without success) to connect a JBL SB100soundbar to a Samsung ... Since your sound bar has an optical in then problem solved. .... a b x TV. August 5, 2013 10:32:42 AM. something like this should do ...
How to Connect a Soundbar to TV audio - YouTube
? 3:19
Nov 22, 2013 - Uploaded by All About Home
The issue is not how to plug the cables in, it's all color coded and easy. ... I have a Sanyo sound bar but it won't connect to my LGtv nor my ps4! Sound Bars
Jan 10, 2016 | Vizio Televison & Video
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Jan 07, 2015 | Samsung Televison & Video
My Nakamichi soundbar won't hook up with my seiki tv I've plugged it into both L R ports but no sound. The bluetooth works just fine so it's not the soundbar
Make sure the two ports that you've connected to are outputs. Then disable the built in TV speaker and adjust output volume on the TV.
Dec 25, 2014 | Televison & Video
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
How to hook up sound bar to phillips lcd tv
there is no hdmi on the soundbar???
Dec 18, 2008 | Televison & Video
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 130 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
