Question about Refrigerators
Frigerator not cooling
Okay, here goes. Both fans are running, compressor getting warm, but not kicking over. I do hear a clicking noise, like the compressor is trying to kick in, but never does. It will do this every 5-10 min. It clicks twice. I have tried unplugging it for hours, thinking maybe it would reset. I was out of town Saturday night and came back to a warm frige. It was stormy that night, so I don't know if the power was surging. Please tell me this is a small part that can be replaced and not the compressor. I have a Roper RT21LMXKQ00. It was made 1-02. So it not that old, just old enough that the warranty just expired. GO figure. I did clean the coils about a week before this happen. the freezer is working fine fridge is however is not cooling down, it is at 60 degrees, I cleaned the coils that did not help, the fridge also has alot of water standing in bottom all the time even when working correctly.. so basically two problems I need help with quickly. thank you. product is a Roper RT21LMXKQ
  • 943 Answers
HI thanks for the question. the water at the bottom means a clogged drain tube. which would cause the fridge not to get cold. its blocking the air vets , so the cold air, cant get down to the fridge section. . remove back wall ,of the freezer and clean all the ice build up. the drain tube goes all the way down, to the bottom drain tray .clean that tube. thanks the appliance doc. please rate my answer.
Posted on Oct 07, 2008
Not freezing or cooling and compressor clicking on and off
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Mar 29, 2014 | Maytag MZD2766GES Side by Side...
Compressor doas not kick on ,when it try,s to-the fan speed drops for aprox. 3 seconds ,and then the fan goes back up to speed but no compressor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Refrigerators
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
4. Wait one hour.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Aurora side by side frigerator fan runs but comressor does not come on.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101 .
Oct 24, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling, compressor and condensor coil fan not running.
It sounds like you may have bad starting components on your compressor. I would check your condenser fan motor for 120v. Or try to put a small box fan behind the ref blowing directly on the compressor to aid in cooling it. If the compressor kicks in then you know the problem is with your condenser fan motor and not your compressor. If the start components are bad you will usually hear a clicking noise from the compressor every 10-15 mins or so.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
pull the thermostat out and short the two wires together and see if the fridge cools,
Apr 17, 2007 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
241 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
