Question about Toshiba Satellite A85-S107 Notebook
Keyboard replacement I need to find a service manual for the Toshiba Satellite A85-S1107 to replace the keyboard. I have taken out all of the screws, but I still can't find out how to take the laptop apart. I need some help. Thanks, Scott
  • Bianca
    Bianca Oct 29, 2013
    thats a good idea to do!!!!!
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
Posted on Oct 15, 2008
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
How to remove and replace the keyboard on a Toshiba notebook
Manual at Here (http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK)
it should tell you in there, you may need a positive screw driver as well
Feb 12, 2010 | Toshiba Satellite Pro L300 Notebook
How do you remove the keyboard to replace it with a new one
Removing the Keyboard
To remove the keyboard, first remove the battery pack, then follow the steps below.
1. Open the display panel.
2. Insert a thin tool into each of the narrow holes in the strip cover and lever the strip cover up to release its latches.
3. Remove two M2.5×3 silver screws securing the keyboard.
4. Lift the keyboard out and place over the display hinges, revealing the keyboard cable.
5. Disconnect the keyboard cable and remove the keyboard.
Below is the link for your service manual for future refernce. It is free to copy, print and use.
http://tim.id.au/laptops/toshiba/satellite%20p20-25.pdf
Nov 19, 2009 | Toshiba Satellite P25-S507 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A85 Optical Drive swap
36ec1a1.jpgHi, this is not the best picture but its this751c93d.jpge only one I can find so far. and yes screws can be hidden underneath stickers I have seen that before.
e3bbac5.jpgsave these to your computer and use a photo program to enlarge them so you can see them.
I hope this helps.
Oct 26, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
Replace A Keyboard
There are websites out there that will walk you step by step on how to do it.
Just do some Googling to find one.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A85-S107 Notebook Logo
218 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
