Question about LG WM1812C Front Load Washer
Washer drum off balance
I have an LG WM1812CW front loader washing machine purchased brand new January 2005. Last week my drain pump went out on my machine (of course, no extended warranty). Local repairmen came out and did the repair, and I mentioned my machine seemed to be out of balance when washing clothes, especially in the spin cycle. We have our machine on a pad to cut down on the vibration as the washer and dryer are both on the second floor, and they said I do not need to have it balanced because it is on the pad (which makes no sense at all). Of course it needs to balanced so we ended up balancing it ourselves, but now have noticed problems when the clothes are in the final spin cycle. I have to press down on the machine as it vibrates so much. This is a new trick since they "fixed" my drain pump and was not doing it before. Any advice? Thanks much.
  • 4 more comments
  • zappy1990 Oct 08, 2008
    The original repair team who replaced the drain pump specifically mentioned there was no problem with the drum.
    Repair team specifically stated there was nothing wrong with the drum. I am hoping this is a simple fix I can do. Any ideas? Thanks much!
    Can I balance the drum myself or do I have to call for service again? If I can, how?
    Can the drum be off balance? If so, how to balance it? Thanks much.
  • zappy1990 Oct 09, 2008
    There is no powder or residue found. Thank you very much for your input. I appreciate your time.
    I have also read these previous postings for help before posting my problem to no avail. Thanks, though.
    President:
  • 1,263 Answers
There is an alignment track that the drum rides on it uses little wheels that ride on this track to keep the drum in the right place. either the bracket holding thos wheels to the back of the drum are loose or the wheels themselves are worn. these should be checked for servicabilty or replaced the problem is not the drum itself.. please rate.
Posted on Oct 09, 2008
    Master:
  • 505 Answers
This is a common problem. You need to lubricant the washer of the pump as well as the spin machiene. As far as pad is concerned, automatic maciene do not require any such thing.
Thanks.
    Brigadier General:
  • 6,966 Answers
May I offer a remote possibility? Pls check the inside of the unit from the rear. Visually inspect for presence of rusty or grayish spray or powder particular at the bottom/flooring, sides and below the rear of the drum itself. Should this be the case, then most likely the bearing at the rear of the drum is damaged which could lead to unbalanced condition and therefor vibrations. In most instances, bearing failure could be caused by fault in the seal. The seal prevents water reaching/damaging the bearings. It would be more economical to replace the seal/bearing rather than an entire drum assembly, but it would require more work and a press shop to fit in the new bearing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,913 Answers
Your washer drum is not fix properly.
pls chk all componentes of motor and washer drumm
refix them again.
and balance thm
Posted on Oct 07, 2008
    Scholar:
  • 116 Answers
Replace the drum simple.and it will be perfect.as it cannot be repaired.
  • mastermind10 Oct 09, 2008
    it may also happen due to this
    please check
    More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
    1 of the fixya expert suggested this as per his personal experience see if this helps you because he was also facing the same problem as yours so here is what he did
    We had the same issue with our Whirlpool and LG front loader washer. Here is how we had to solve the problem.
    The floor was vibrating so much did the spin cycle, so I call a freind of mine over that is contruction engineer. He suggesting putting 2x10 blocks between the floor joist in a ten foot section. Retested, this reduced the the amount a vibration, then we screwed a sheet of ¾" Plywood on the bottom side of the joist. This cured the vibration. If you read the installation instructions, they only talk about installing the front loader washers on solid surfaces (concrete) to avoid vibration.
    please rate the solution if it helps.
    and do comment if need further help.we will help you.
    thanks.
My front loader washer gets stuck on its last spin and wont drain properly. I am trying to wash a comforter and blanket. This is the 1st time its happened. Thank you
You may to mention the brand and model of machine. Mine is an Lg, I just shut off machine. Turn it back on and then press the no spin and start, this drains the washer. You may have too much clothes in the machine.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
My lg wm1812cw washing machine is not draining properly.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 03, 2011 | Washing Machines
My LG TROMM model # WM1812CW has a burning rubber smell when it's on the last high speed cycle. Can you help me locate the problem?
I just ran into this same situation. The problem was that the basket has been rubbing against the tub/door gasket. In this specific case it finally wore through the tub and was a hole through it. It si looking to be approx a $600 repair.
Sep 03, 2010 | LG WM1812C Front Load Washer
BRand new installation of 1 year old machine we
hi,
I am a novice at front loaders but it sounds like it needs new suspension parts, namely springs, sounds like the machine had a hard life before you got it. since its used anyways it cant hurt to take the back off and see and study how it works and how the drums suspension works. you can try to find the springs at an appliance store. Im not sure if you can get springs directly from LG. LG's are a pretty good name brand, probably worth fixing..
good luck!
jm
Dec 28, 2009 | LG WM-2277HW Front Load Washer
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
LG WM1812C Front Load Washer Logo
761 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
