Question about Admiral AW22 Top Load Washer
Grinding noise,unit stopped, burning smell?
Washer started making grinding noises, unit stopped completely, burning smell.
Just had the repair man come out for the same problem....tranny gone, $600 to repair. Only 3 years old. Disgusted. Good luck.
Posted on Oct 13, 2008
    Problem Solver:
  • 10 Answers
Broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Posted on Oct 08, 2008
Car was running, electrical wire burning smell, starter makes grinding noise, with the car running, stop the car, starter keeps making grinding noise, with the car turned off, ABS and trac control
You have the polarity of the battery backward somewhere. Did you replace the starter and hook it up backwards. Difficult but possible. Check your positive and negative on the battery itself.
Nov 23, 2015 | 2001 Mercury Grand Marquis
2003 Mazda Mazda6 V6 Overheating + Grinding Noises
Is the serpentine belt still intact? The grinding noise maybe the water pump which would account for the overheating.
Feb 17, 2014 | Cars & Trucks
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
During spin cycle a grinding noise starts and a burning smell develops if I let it spin on then smoke comes out
could be your motor coupling, clutch or brake linings. if it smells like rubber burning then it is your motor coupling,, ,,,,mine was doing that and found out the clip that holds on the part to disengage the brake had ground off the end of my basket drive tube and the arm fell down thus no spin ,part cost more than the washer is worth! guess i'll be picking up a new 1! yea the grinding noise could be in your clutch,brake area!
Feb 10, 2010 | Kenmore Washing Machines
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Bad sounds, bad smells from 94 ford explorer
Sounds like you may have a vacuum line off or ruptured going to the EGR valve. The burning smell is probably the catalytic converter. When the engine runs rich you will get a sulfur smell that smells sort of like rotten eggs.
Mar 15, 2009 | 1994 Ford Explorer Limited
Admiral AW22 Top Load Washer Logo
353 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
