Question about Cameras
Casio Exilim optical 3x 8.1 mp will not take picrtures out doors all pictures come out white, day or night. Dose fine inside but not out side.
SOURCE: My camera CASIO EXILIM EX-Z600
I have a EX-Z600 and i tried updating the firmware to a 1.03, as i did the 1.02. Doing exactly what the instructions say. Now after i placed the update in the root directory and taking the camera off the cradle i was pressing the menu button and pressed the on button to get the program update page but the camera screen would only show version 1.02 then it would turn on. Why does it do that? I have also had the problem, since i got the camera, that sometimes the camera wont turn on unless i take out the battery and put it back in, why is that? Can anybody please help me.
Posted on Nov 30, 2007
MarkDay
  • 111 Answers
SOURCE: casio exilim Z77 optical lens error
Sorry, but no, I do not have parts for this camera.
Posted on Jun 11, 2008
  • 374 Answers
The warranty isn't going to cover if you drop it so you would have to pay for the charge. You can bin it if you like. That is your choice.
Posted on Sep 10, 2008
  • 11967 Answers
SOURCE: Casio Exilim EX-S600D creates "white pictures"
Check the ISO setting...it may be too high. Also, check the white balance.
Posted on Sep 04, 2009
BillB-SA
  • 2761 Answers
SOURCE: my batterie died on my casio 10.1 mp exilm camera
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Jan 04, 2010
Sep 04, 2009 | Casio Exilim EX-S500 Digital Camera
When i capture a pic in day light than picture will come faded and when i capture in night it comes nice one my camera model is exilim ex z60
make sure the camera's settings are set to normal, since, the lens might be sensitive to daylight. You can actually change this at the settings, and, you said that it works fine at night or at dark areas? Yeah, the lens could be sensitive to bright lights! Simply adjust the sensitivity and you're all set!
Jun 25, 2009 | Casio Exilim EX-Z60 6MP Digital Camera...
White pictures
There is sand or grit inside of the camera. you need to open it up and take the sand out. but beware of the flash wires. packs a mighty jolt.
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
This is a CCD failure. Go to the Casio Tech support team. There has been an issue with a batch of CCD's and a recall on certain models of all makes This may be one of them
Jul 16, 2007 | Casio Exilim EX-S500 Digital Camera
Cameras Logo
654 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
