Question about Tappan MGF500PBW Gas Kitchen Range
Gas smell when cookin and not is there a pronblem with regulator
Any known problems or recalls
  • versande5 Oct 09, 2008
    THANX DOC WILL TRY IT
  • versande5 Oct 10, 2008
    CAN A REGULAToR be the problem and be adjusted this the second stove we have had brand new from LOWES
  • 943 Answers
HI i would replace the gas igniter in the oven. when a glow coil comes on. its suppose to glow a white hot glow. that then ignites all the gas. when its failing it glows an orange color. and that's not hot enough . replace the igniter. the appliance doc please rate my answer.
Posted on Oct 07, 2008
Why is there gas in the intake tube?
You mean gas in the air intake??
Apr 14, 2016 | Cars & Trucks
Ford e 350 runs rough blows black smoke until you restart it
the truck is either an e350 0r f250 right? now which?
Gas powered rigs ? call the dealer to inquire about outstanding recalls. inspect your fuel pressure regulator for the correct number
F4TZ or newer should be seen. check the oil dipstick for a fuel smell. if the spark plugs show excessive fuel or carbon. change the oil first, and the filter. then use an update regulator, and tune up.
diesel rigs? theres a possibility of fuel injector pump and or injector problems. first determine the glow plug system is right. see a diesel tech about what diesel fuel system yours is equipped with, do the required maintenance, and with good parts does it smoke cold only, warm only or both. then you can begin to get answers. several systems were used and engine displacement must be known to look it up. a faulty glow plug controller or inoperative glow plugs can contribute to cold smoke, a faulty injector pump or leaky injectors can cause warm smoke. some diesels have the newer system and there are a series of updates you must have. parts are very expensive so do your homework first. build date, engine size, injector type, outstanding recalls, tsb's tech service messages. these can all be found at the ford dealer. they will be happy to answer your questions.
Feb 02, 2014 | 1994 Ford F250 Supercab
Gas smell in car
I had a Buick Rendezvous that did this. Turned out if was the neck of the gas tank breaking away from car. It was a factory recall, but not before I paid to have it done. Look for problems on your car online and see if any mention this same problem. There may be a problem of which you are not aware.
Dec 08, 2013 | 2006 Saturn L300
Smell and see gas 2001 expedition
Do not start or use Vehicle. If in Garage, do not use the garage door opener. Manually open the door to Garage. Call tow truck with a flatbed. Have vehicle towed to open location.
There were some vehicles with Recalled gas tank straps. But anything could be wrong. The fix may be reasonable.
Call a Dealer with your Vin# to see if yours is an affected Recall.
Apr 16, 2013 | 2001 Ford Expedition XLT
2005 impala smells like fuel at start up and while driving, gas tank not leaking. smell fumes worist @ morning starts even when heater off and vents shut
its your fuel pressure regulator. pain in the rear to change. its the small brass looking thing next to the throttle with a vacuum line going to it . the part cost me 50$ and i paid a guy $ 75 to put it in. worth every penny. looks easy to change yourself, but not as easy as it looks.
Mar 03, 2010 | 2005 Chevrolet Impala
99 lesabre getting hard to start even though it turns over fine. Problem seems to be worse after sitting over night. Smell gas after coming home from driving.
Check out the fuel filter, also look for a fuel leak in the manaflod area. When you go to start it, turn the key on for 10 seconds before you try to start the engine and then turn it over and see if it doesn't start easier. If the fuel pump is getting weak it gives it a chance to build up pressure.
Aug 16, 2009 | 1999 Buick LeSabre
Kia Rio Check Engine Light
check the fuel line hose near the fuel regulator for wear as they tend to leak or corrode causing a gas smell inside the car. My 2000 Kia Sportage just had the same problem with the gas smell inside the car.
Dec 11, 2008 | 2002 Kia Rio
Smell of gas fumes underneath vehicle near fuel tank
this sounds like a gas pressure regulatur. a few minutes after starting,you start smelling fumes,and are getting bad gas mileage right?
Nov 16, 2008 | 2004 Volvo XC90
Marshall control valve . gas regulator valve
Replace the regulator as this is typically an issue where the diaphragm has separated from between the body and bonnet. This is not repairable. There is no recall for this as was in the case of the 450 regulator as it is a manufacturing variance that happens with all products. It passed initial QC, but in time the diaphragm moved.
Oct 24, 2007 | Thermos Stainless Steel Gas Grill
Tappan MGF500PBW Gas Kitchen Range Logo
143 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
